In much need of suspension help!
nitro521
Page 2 of 2
Page 2 of 2 • 1, 2
Re: In much need of suspension help!
If the car is leaving without spinning i would concetrate on other things for the time being.
Richter, I agree, but getting ready to put more gear in it and I know it wont hold. Trying to get a handle on the suspension and be ready.
nitro521- Posts : 22
Sometimes they work better with more power or gear........... Just make one change at a time.
And you can call me fabio.......
Ok Fabio Here is a link to the video, I hope this works.
https://s985.photobucket.com/albums/ae331/nitro520/Race%20car/
nitro521 wrote:Well, I have been working like crazy the last few days, finally got some time to try lifting the rear 1" and take some measurements. Here is what I came up with.
IC length 39.79 IC height 8.868 Anti-squat 102.515
This put the lower front arm at 9.125". I am thinking I am goint to have to move some mounting points, what do you guys think?
Still need more rear height or lower front end more. need more angle in the lowers.
whatbumper- Posts : 3024
Ok Whatbumper, what numbers do you think I need to get to so it will work? With the rear raised 1" that put the fender lip at 27", I will raise the rear and lower the front a little more and take measurements.
nitro521 wrote:Ok Whatbumper, what numbers do you think I need to get to so it will work? With the rear raised 1" that put the fender lip at 27", I will raise the rear and lower the front a little more and take measurements.
I just saw the video. Rear is too low and the front is too high. I know that may be what look you are going for but stock suspension is pretty finicky. I don't know exactly without being at your car as the numbers are concerned but with your combo you would want the front of the lowers to be higher than the rears and I don't think it is with your numbers but I could be wrong . It all depends on your specific tire/wheel combo and your front heights. You have a LOT of antisquat by watching the video. You will lower that and move the IC by just changing the ride heights.
Page 2 of 2 • 1, 2
Page 2 of 2
