91 lx coupe sleeper build !
+18
2fox
mpinder18
paulie
chimmechurie
83-88T-Bird Guy
D's557BBF
nuclearcobra
bb429power
8liter
meteor545
droppedf100
Northwest outlaw
89lxcoupe
22 posters
Page 2 of 2 Previous  1, 2
91 lx coupe sleeper build ! - Page 2 Empty Re: 91 lx coupe sleeper build !
Post  89lxcoupe August 9th 2010, 11:22 pm
droppedf100 wrote:Looks good. If you want to get rid of that huge power steering bracket let me know.
nope using it. Sorry !
89lxcoupe
Post  89lxcoupe August 16th 2010, 11:14 am
well heres a little teaser video from start idle and a couple of revs ! i did get the rear brake line hooked up and adapted to the body, also finished up a few things so all i need now is a shifter and exhaust done to get the last main things done and get my fuel pump issue lined out so i can drive it !
turn your volume down so you can hear the cam better, sorry its so muffled !
91 lx coupe sleeper build ! - Page 2 Th__IMG_0037
89lxcoupe
Post  D's557BBF September 12th 2010, 11:19 am
How's is your project coming? any more updates for us?
D's557BBF
D's557BBF
Post  89lxcoupe September 13th 2010, 2:22 pm
here are a few pictures of the car as of right now. i got the exhaust put on it and love it. 3" x pipe into 2.5" super turbo mufflers with turn downs. installed my wide band and have the idle fuel mixture spot on. i have the car drivable but the c6 is shifting very strange.
91 lx coupe sleeper build ! - Page 2 IMG_0893
91 lx coupe sleeper build ! - Page 2 IMG_0889
91 lx coupe sleeper build ! - Page 2 IMG_0890
91 lx coupe sleeper build ! - Page 2 IMG_0891
89lxcoupe
Post  83-88T-Bird Guy September 13th 2010, 10:02 pm
Your coupe is looking good !
Are you using Turbo Coupe rear axles? I see you have the brakes.
How have your 1.5 inch k-frame spacers worked out for you ?
Also, how much hood clearance do you have under the stock hood?
I bought a 91 coupe Saturday so I have to start on mine soon. Very Happy
83-88T-Bird Guy
83-88T-Bird Guy
Post  89lxcoupe September 22nd 2010, 2:21 pm
83-88T-Bird Guy wrote:Your coupe is looking good !
so sorry for the late response, for some reason i'm not getting notifications !
the spacers work good, it did make using the stock steering shaft impossible i have pretty good clearance. i have a torker 2 intake with holley 750 drop base air cleaner and still have over an inch of clearance, i can put my old school 125 holley nitrous plate on it and its 1" thick and still have room to close the hood ! and yes i'm using the turbo coupe axles ! man i love your midnight blue coupe...... i had a 93 hatch and wished it was a coupe. my 91 is getting some fresh silver paint maybe next month !
89lxcoupe
Post  89lxcoupe September 23rd 2010, 2:30 pm
well i took the car to the dump today and weighed it ! ended up being 3260lbs with me in it and i'm 195lbs so its about 3065lbs. not bad considering its still pretty much stock. the only things removed from the car are sway bars rear seat and sound deadener insulation and misc airbag sensors !
89lxcoupe
Post  89lxcoupe October 27th 2010, 11:18 am
i just wanted to let you guys know that i have been having fuel problems and the carb has never acted right since day one. i went to the track 2 weeks ago and had fuel pressure problems, come to find out my tank was rusted and the more i drove it the more rust was stopping up every piece in my fuel system, i have since then put in a new fuel tank installed a bulkhead fitting in the bottom of the slosh tank and flushed my line and cleaned out the fuel pump reg and carb, and bought an 850 to try ! the carb has never felt right when the 4bbl would come in and was very lazy. long story short the fuel pressure would drop to 1-2 psi after i left the line and went to 0 before the 1/8 every run and managed....
1st run 36 deg timing
1.82 60ft
7.87 1/8 et
90.39 mph
12.57 1/4 et
88.06 1/4 mph (let out) checking brakes we have a very short shut down !
2nd run 36 deg timing
1.83 60ft
7.90 1/8 et
90.20 mph
12.25 1/4 et
112.83 mph it about died at the end when i let off because the bowls were dry !
3rd run 32 deg timing
1.87 60ft
7.97 1/8 et
89.97 1/8 mph
12.33 1/4 et
112.46 1/4 mph still about died because of no fuel in the bowls
all in all i can't believe it ran what it did with no fuel pressure. can't wait to run it again with the fresh fuel system and the 850 dp !
89lxcoupe
91 lx coupe sleeper build ! - Page 2 Empty bbf fox
Post  chimmechurie January 30th 2011, 9:01 pm
sweet build dude! any updates on it?
chimmechurie
Post  paulie February 9th 2011, 2:00 pm
looks great I am interested too!
paulie
Post  89lxcoupe February 9th 2011, 2:55 pm
sorry for not updating sooner. At the moment the car is in primer almost ready for new titanium paint,new headlights, cowl panel and window tint. since the last runs at the track i have added a 850dp, advanced the cam to +4 deg and added solid lifters to the a443 cam. It feels stronger than it did but not what i think it should be. The engine doesn't feel right and it now has a smoking problem on start up that it didn't have till after i advanced the cam, so i'm thinking it has something to do with the intake gaskets !
89lxcoupe
Post  res0rli9 April 17th 2011, 8:23 pm
any up date's???
91 lx coupe sleeper build ! - Page 2 Empty k frame spacers
Post  mpinder18 April 29th 2012, 8:52 pm
I have header problems on a 83 502 swap (hooker swap headers). I have an aftermarket k and was looking at your spacers. How much trouble was it to space the k frame?
mpinder18
mpinder18
Post  2fox May 6th 2012, 7:07 am
Cool build man Congrats. Yes there will be bugs. But that's how it goes.
Do all bbf. Swap need the k member spacers?
Did your headers fit without beating on them.
Keep up the good work
I will be checking back in on you
good luck
oh what are u going to do about the master cylinder? Get a manual pedal or modify yours if you modify your get some before and after pics please thanks
2fox
Post  5pointslow November 27th 2012, 11:46 am
any updates with better carb???
5pointslow
5pointslow
Post  bbf-falcon November 28th 2012, 1:57 pm
Why did you advance the cam 4*?
Post  bigblok2000ranger November 29th 2012, 1:34 pm
Better hope that you didn't burn the valves I had a fuel starvation issue one my old 466 and burnt a few valves and wore out some guides, they don't like running out of fuel at 6000rpms!
bigblok2000ranger
bigblok2000ranger
Post  clodracer2000 December 19th 2012, 5:51 pm
Hey what cross member and tranny mount did u use?
clodracer2000
