28x10.5 SS Guys...What are you 60 footing?
+18
dr's wife racing
bigblockfox468
Notch 501
jmayabb
mikep
Barney
Larry Williams
Matt Jewell
Jeremiah
studly
yellowhorse7
22 posters
Page 1 of 4 1, 2, 3, 4  Next
28x10.5 SS Guys...What are you 60 footing? Empty 28x10.5 SS Guys...What are you 60 footing?
Post  yellowhorse7 August 9th 2010, 10:32 am
Like the title says, what are you stock suspension guys 60'ing on a 28x10.5? We've been dealing with wheel spin issues all season and we are finally getting close. Looking for higher powered (775+), automatic car info. Thanks
yellowhorse7
yellowhorse7
28x10.5 SS Guys...What are you 60 footing? Empty Re: 28x10.5 SS Guys...What are you 60 footing?
Post  whatbumper August 9th 2010, 11:48 am
Last season with our nitrous sbf with a glide and 3.89 gears we went 1.20-1.21 on good tracks and 1.25-1.26 on mediocre tracks.
28x10.5s tires at 3350lbs. Wolfe rear suspension, single ARB, QA1 shocks, 125lb springs
Post  studly August 9th 2010, 12:33 pm
3320 UPR upper and lowers with qa1 double adjustable shocks factory mustang springs and MT 3055S 1.34 BBF on NOS 5.60 1/8 mile 127mph still working on it. 3.89 gears Powerglide. going to try more gear.
studly
studly
Post  whatbumper August 9th 2010, 3:16 pm
front spring length and weight rating is very important as well as front strut. I have never had too little traction but I have had wheelie problems in the past because we didn't make enough power for our setup.
On our current setup we are running the 29.5x10.5 tires and are in the low 1.20's again with our turbo setup but we are not even close to how it was setup as a nitrous car. our front end is limited to 1 inch travel now and a full tight setting on the strut. The rear setup is different too. We had to lower the front and raise the rear to get the IC where we wanted it with our new power. It used to be under our butts and now it's out at our feet. Too be honest after adjusting for IC and setting our ARB to 1/2 turn preload on the right and getting the weight right side to side I didn't even check the pinion angle. I probably won't either.
Post  whatbumper August 9th 2010, 3:17 pm
yellowhorse7 wrote:Like the title says, what are you stock suspension guys 60'ing on a 28x10.5? We've been dealing with wheel spin issues all season and we are finally getting close. Looking for higher powered (775+), automatic car info. Thanks
What's your current setup? springs, struts, arb, weight bias, etc...
Post  yellowhorse7 August 9th 2010, 6:25 pm
Front:
Strange 10 ways
UPR Coil Over
14" 175 spring
Rear:
Strange 10 ways
Double adj lowers
Team Z DBl adj Uppers (relocated)
GT spring with 2 1/2 coils out out of each side
uPR ARB
3055S Tire, 4.10 gear
58% over the nose (iron head)
Car weighs 2960 race ready
IC is right at 38.5" and AS is 141%. IC height is 10.2 inches
Been working with Team Z for a few months and the best 60 ft to date is a 1.401. Still spins 1 revolution before the car even moves, which is down from 2 1/2 or so. Front has been on full loose and rear is 3 clicks from full loose. We're think the converter is still too tight
yellowhorse7
yellowhorse7
Post  Jeremiah August 9th 2010, 6:32 pm
1.33 60ft. 29.5/10.5 Stock susp coupe... QA1 coil overs all the way around..
Jeremiah
Post  whatbumper August 9th 2010, 11:19 pm
I didn't think Dave would let anyone run 14"springs. I don't know anything about his relocated stuff.
If you have Dave Z working with you then there is nothing we can say here that is better. He could get bicycle with a small block to hook I think. lol!
Post  yellowhorse7 August 10th 2010, 8:08 am
whatbumper wrote:I didn't think Dave would let anyone run 14"springs. I don't know anything about his relocated stuff.
Lol, you are correct with the bike! It seems that he like the 14" springs for BB cars. The 12" is for most SB cars.
yellowhorse7
yellowhorse7
Post  Doug Rahn August 21st 2010, 6:49 am
Best so far with my junk is 1.33-60' with the 28" tires. We haven't been to the track since the Bash, too damn hot here! Sixty had dropped off a little, but I'm still playing around with IC. Once I get it nailed down, I'm confident it will 60' in the 1.20's.
Post  bruno August 21st 2010, 8:18 am
sad to say my 60's on a 3055s is a 1.31 , just wish i had more time to test ....
http://WWW.CKRME.COM
Post  Doug Rahn August 21st 2010, 8:25 am
bruno wrote: just wish i had more time to test ....
Same thing here Nick! I've had some personal issues going on which have prevented me from doing anything and it's been to dang hot anyway. But now all is good with the personal issues, just don't have the funds to do much right now Sad .
Post  richter69 August 21st 2010, 4:16 pm
been a 1.29..............but it was a W so it dont count. Laughing
Post  IDT-572 August 29th 2010, 8:03 pm
1.29 was my best when I ran 28 x 10.5's
Post  Matt Jewell August 29th 2010, 8:17 pm
I had a 1.37 60ft on a 275 M.T. Radial mounted on an 8'' wheel. The next pass it blew the tires off. That was with 90/10 Lakewood struts, stock front springs, Strange economy adjustable rear shocks and stock rear springs. I have never bettered that mark after going to QA1 adjustable front coilover conversion, Varishock rear coilover kit, adjustalbe lower control arms and an Anti Roll. I'm sure it's my chassis tuning skills, but something to be said for the K.I.S.S. system (keep it simple, stupid).
Matt Jewell
28x10.5 SS Guys...What are you 60 footing? Empty Update
Post  yellowhorse7 September 29th 2010, 9:32 pm
1.311 60 and 5.90 in the 1/8. Haven't even started to make it sweat yet.....
yellowhorse7
yellowhorse7
Post  whatbumper September 29th 2010, 10:09 pm
yellowhorse7 wrote:1.311 60 and 5.90 in the 1/8. Haven't even started to make it sweat yet.....
That sounds a lot better. May I ask what you did?
Post  yellowhorse7 October 2nd 2010, 5:13 pm
Took another 1/2 coil out of the rear springs (2.5 total), which raised the A/S value a ton as well as lowered the IC. Carries the front end about 10 inches. But the single most important factor was the new Ultimate converter. It's 2400rpm tighter!!!
The last 5.90 pass I lifted @ the 900 foot mark and still went 9.31. That pass would have been 9.teens for sure. This thing will go 8.80's without much effort. Dave and Lenny have been GREAT!!!
yellowhorse7
yellowhorse7
Post  Larry Williams October 2nd 2010, 7:28 pm
my n/a small block went a best of 1.34 60 ft with 28 x 10.5 after I installed 12" x 150 front springs
Larry Williams
Larry Williams
Post  jbozzelle October 4th 2010, 8:50 pm
Best for my friends car (I've been tuning the suspension on it) is a 1.42 on a 275/60 MT Radial.
It's got Strange adj struts up front with coil overs (don't know the spring rate), QA1s out back, some red looking factory style springs,Adj uppers and lift bar lowers. I have NO idea where the IC is at. I haven't plotted it. It works good enough though. Car is powered by a 383 SBC, 1.82 glide and 4.10s out back...
I picked up .3 just by tuning the suspension alone. We just stuck the 383 in it and are still tuning it. It's getting faster in the 60' every pass. I'd like to try some solid lowers and ditch the lift bars, but it hooks too damn good.
Post  whatbumper October 4th 2010, 9:49 pm
jbozzelle wrote:Best for my friends car (I've been tuning the suspension on it) is a 1.42 on a 275/60 MT Radial.
get rid of the lift bars. they are hurting you more than helping. you will be able to keep it hooked up without the lift bars. Unless that turd chebby motor has NO power!! The local True Street class here which is a 275 class has guys in the 1.20's but I see no reason that mid 1.30's aren't possible with any decent power car.
Post  richter69 October 4th 2010, 10:05 pm
we got a set of Southside lowers on the turd.............. Very Happy
Post  whatbumper October 4th 2010, 10:21 pm
richter69 wrote:we got a set of Southside lowers on the turd.............. Very Happy
they work great on low torque applications. Anytime you start adding power they hit so hard that you can't keep it hooked up.
Post  jbozzelle October 4th 2010, 11:39 pm
This bowtie turd hasn't spun yet. I would know since I'm usually kneeling down behind it!
I've tried to talk him into ditching them... He's got a Chevy in a Ford. You tell me if he'll listen to reason!!!!!!!!!!!!!!
Post  Barney October 5th 2010, 10:21 am
Not to mention they DESTROY the car, and are unpredictable at best.
Barney
Barney
