Gear change update
+11
512Fairlane
Greg_P
64 fairlane
Tore
15 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Gear change update
I have had a terrible time with this 64 Falcon I bought. I couldnt get it to run any faster than the 10.20s 122-125 mph. I did change the stall on the converter over the winter.This was the same drivetrain that was in my Blue 71 Cobra Torino. We swapped out fuel pumps,ignitions, Etc . I was really disgusted and pissed off. I have never struggled so much with a car.
I also posted on here about a low ratio gear set in a C6 and some said it would hurt me but I couldnt understand why it worked good in the Torino and not the Falcon.
Blake thru up a post about a situation and alot of people responded and they said it would hurt the times. So what the heck I had a set of 3.91 gears set. This was my easiest thing to change. Well I went from 10.20s to 9.87 just by swapping the gears. My best last week was 9.87 130.00 miles per hr. I had 4.30s with a 32" tall tire. SO I have pulled the low ratio tranny out and am in the process of putting in a standard gear ratio tranny and racing this Friday. I will let you know how I make out. So I guess you can gear to low.
Tore
Tore
Tore- Posts : 865
Re: Gear change update
yep, BB dont like all that starting line ratio.................thats why the glides works so well when coupled with the right gearing and converter.
Congrats on the numbers............
what is the engine specs. on this and whats the wt.
res0rli9- BBF CONTRIBUTOR
514ci, 14.5 to 1 comp, roller cam and P51s ported by Charle evans, Car weighs 3550 with me in it.
Tore
Tore
Tore- Posts : 865
I'd sell that c6 crap and stick a glide in it........................
Not right now I got 3 C6s sitting here. And I am on the austerity budget right now,
Tore
Tore
Tore- Posts : 865
Do you have any pics of your car Tore?
jasonf- BBF CONTRIBUTOR
Tore wrote:I have had a terrible time with this 64 Falcon I bought. I couldnt get it to run any faster than the 10.20s 122-125 mph. I did change the stall on the converter over the winter.This was the same drivetrain that was in my Blue 71 Cobra Torino. We swapped out fuel pumps,ignitions, Etc . I was really disgusted and pissed off. I have never struggled so much with a car.
Tore
Thank you very much..................
Tore wrote:Not right now I got 3 C6s sitting here. And I am on the austerity budget right now,
Tore
Sell the three, get one 'glide.....
Nevs- BBF CONTRIBUTOR
Tore,
A 9.87 is good but it seems like the MPH should be better than 130 for that ET?
Later Mark.
Later Mark.
Mark Miller- Posts : 1948
Mark Miller wrote:Tore,
Later Mark.
With the gear swap its happy on the bottom but not so on the top........its laboring in high gear now.
I'd say if you converted to a glide you would probably pick up 2 more numbers and the car might even hook in the rain. The glide calmed my leave down and the car just worked much better. It let the suspension work instead of screaming past the usable torque numbers you have. JMO
Travis
Travis
TravisRice- BBF CONTRIBUTOR
richter69 wrote:Mark Miller wrote:Tore,
Later Mark.
I told him to change the gear to prove that it would pick the car up by reducing his first gear FD ratio. Now he needs to put the standard first gear ratio planetary back in and go back to his 4.30 ring gear. Wit the low planet there is a wider gap between 2nd and high that hurts the car from getting in high gear in the sweet spot. Could be whats up with the mph.
Yes I knew the gear swap was a easy experiment...............that proved to be correct...........
I am leaving the 3.91s in right now and will see what happens. I have some 4.11s and 4:30s to try but one thing at a time.
Tore
Tore
Tore- Posts : 865
TravisRice wrote:I'd say if you converted to a glide you would probably pick up 2 more numbers and the car might even hook in the rain. The glide calmed my leave down and the car just worked much better. It let the suspension work instead of screaming past the usable torque numbers you have. JMO
Travis
I agree with you Travis totally............ But what he is doing is cheap now because he has the three speeds. But it is proving a point. Giving direction on where to go. The car will pick up with a glide.
I think it is still geared to low in first for an efficient leave. That's a 10.63 final where he is now. 10.63 / 1.76 (glide ratio) = 6.04 ring gear with a glide to get a 10.63 final.
Example is Chuck Hagger's 69 Mustang 29.5 tire 4.56 gear with a glide. 3500 lb. Same weight car less engine (492) TFS streets, running less gear. I think he ran a 10 flat and in the low 1.4 60ft's. 8.03 first gear F.D.
With that gear he had to lift early through the quarter because it was getting over 7000 rpm before the stripe. He needs a 4.30 for the 1/4 mile
Tore wrote:I am leaving the 3.91s in right now and will see what happens. I have some 4.11s and 4:30s to try but one thing at a time.
Tore
Are you going to put the stock first gear C/6 back in it with the 3.91 and see what happens?
Yes its going back in today. I have to see what its going to do.As I stated I have the other gears all set up.
Tore
Tore
Tore- Posts : 865
With the 3.91s I was shifting at 7k and going thru the traps at 6500 rpm.
Tore
Tore
Tore- Posts : 865
rough numbers with what you posted thats like 19% on the converter slip....
gear swap
Hey guys reading this post has made me think about my own combination. Would a gear swap hurt or improve my over all ET. I have 3400# 64 fairlane 30 inch tall tire 4.56 gear C6 4500rpm converter 60 foot is 1.38 and 1/4 mile at 135 9.99 sec at 7100 rpm. If I changed the rear gear to a 4.30 or 4.11 do you think my 60 foot would improve. Aaron
64 fairlane- Posts : 47
You just have to try stuff, gears, tire sizes, converter set ups etc. Not every swap thats good for one combo is good for another.
Later Mark.
I agree, our best of 9.95 came with darn near 136 mph..... 3.89 gear and 29.5" tire.
Greg_P- Posts : 1009
Tore wrote:Yes its going back in today. I have to see what its going to do.As I stated I have the other gears all set up.
Tore
Can't wait to hear how this works out. Keep us posted. When will you get to run it next?
512Fairlane- Posts : 694
Guy's ,
I fully understand what you are trying to accomplish on a budget with what you have. Given the info that you are providing and seeing which direction the car is going (faster) my suggestion would be to start saving $$$ for a glide. The car is definatley heading in the right direction. Be interested to see what the rest of the year holds as far as et and mph gains with what you have. Keep after it.
Travis
Travis
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» Gear change question
» Pro Stock Trans gear ratio / Rear Gear
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
Page 1 of 3
