Gear change update
+11
512Fairlane
Greg_P
64 fairlane
Tore
15 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Gear change update
Well I went tonight and I still had the 3.91s in but switched to a C6 with a standard gear ratio. Well the car picked up it went to a 9.728 at
138.33 mph. I was shifting at 7k went thru the traps at 6600 right about there. It was a good night. I will try the 4.30s in another week and see where it goes. Tore
Tore wrote:I have had a terrible time with this 64 Falcon I bought. I couldnt get it to run any faster than the 10.20s 122-125 mph. I did change the stall on the converter over the winter.This was the same drivetrain that was in my Blue 71 Cobra Torino. We swapped out fuel pumps,ignitions, Etc . I was really disgusted and pissed off. I have never struggled so much with a car.
I also posted on here about a low ratio gear set in a C6 and some said it would hurt me but I couldnt understand why it worked good in the Torino and not the Falcon.
Blake thru up a post about a situation and alot of people responded and they said it would hurt the times. So what the heck I had a set of 3.91 gears set. This was my easiest thing to change. Well I went from 10.20s to 9.87 just by swapping the gears. My best last week was 9.87 130.00 miles per hr. I had 4.30s with a 32" tall tire. SO I have pulled the low ratio tranny out and am in the process of putting in a standard gear ratio tranny and racing this Friday. I will let you know how I make out. So I guess you can gear to low.
Tore
Tore- Posts : 865
Happy for ya Tore,I think that Coon has a 60 in it. Put the 4.30 in and me and Sooz will meet and go help you next weekend when we come your way.
the mph realy took a jump bitchen!did your 60'change any?
Tore,
That sounds more like it on the MPH and ET,what track did you go to?
Later Mark.
Later Mark.
Mark Miller- Posts : 1948
[No racin next week. Gonna take a break, figured you and Sooz could stack firewood. LOL
Tore
quote="bbf-falcon"]Happy for ya Tore,I think that Coon has a 60 in it. Put the 4.30 in and me and Sooz will meet and go help you next weekend when we come your way. [/quote]
Tore
Tore- Posts : 865
The 60ft stayed just about the same.1.386 was the best.
cool40 wrote:the mph realy took a jump bitchen!did your 60'change any?
Tore- Posts : 865
I was at Empire Raceway. About an hr south of Rochester NY. I would like to hit Thompson before it closes this season.
Tore
Tore
Mark Miller wrote:Tore,
Later Mark.
Tore- Posts : 865
Tore wrote:I was at Empire Raceway. About an hr south of Rochester NY. I would like to hit Thompson before it closes this season.
ToreMark Miller wrote:Tore,
Later Mark.
NYIRP? Thats a pretty decent track for MPH, nice long shut down too.
Yes thats the track. It has a real long shutdown. I was told that was an Air BAse back in the late 40s. The shutdown needs to be worked on a little but its a very nice place. Had 3 guys come and ask me if I had a Ford engine in the Falcon. Alot of Chevy's there and ricers. Wheres a Scud missle when you need it
Tore
Tore
Tore- Posts : 865
Ok guys if I put the 4:30s in what do you think will happen with speed and ET????
Tore
Tore
Tore- Posts : 865
Should 60 a little harder and mph will be about the same IMO
Will find out Sat. I have an 1150 I want to put on but all the testing I am doing has been with the 1050 so we will stick with that.
Tore
Tore
dfree383 wrote:Should 60 a little harder and mph will be about the same IMO
Tore- Posts : 865
keep in mind if you go to a different track, NYIRP has always MPH'd better for me then other tracks in the area.
Tore,What is your Leave RPM ?
I doubt you will see any change with the rear gear change. if you go to the same track. It may lose a little mph.
[ I kind of thought about that. Looking at the numbers on paper. Tore
quote="IDT-572"]I doubt you will see any change with the rear gear change. if you go to the same track. It may lose a little mph.[/quote]
Tore- Posts : 865
Great!
Excellent results! Glad to hear when something works out. I think you should skip the 4.30's and put the 4.10's in it. That will save me some testing . I'm anxious to hear what that 1150 does too, but get that gear situation ironed out first. Thanks for posting the results.
512Fairlane- Posts : 694
Tore
Tore,Thompson has there last 8.90 Renegade race this Saturday your car might fit the rules they're posted on the Thompson website.Later MarkMark Miller wrote:Tore,
Later Mark.
I saw that on their site. I had something come up here at work so its questionable if I can even go tomorrow.
Have to wait and see.
Tore
Tore
Mark Miller wrote:Tore wrote:I was at Empire Raceway. About an hr south of Rochester NY. I would like to hit Thompson before it closes this season.
Tore
Later Mark.
Tore- Posts : 865
Tore,
Keep us posted when you try the 1150,Later Mark.
I just talked to Tore,he is in the staging and has probably made a pass by now. He said he did'nt change the gear,but was gonna make a pass or two then change to the 1150 carb. Hope things go well
Tore did you ever get results on the gear change or switching to the 1150? I'm making the switch back to the 2.46 low and I'm running 4.10s.
Gear change updates
x2,MavMan is also curious of the results?,512Fairlane wrote:Tore did you ever get results on the gear change or switching to the 1150? I'm making the switch back to the 2.46 low and I'm running 4.10s.
1970 ford maverick- Posts : 180
Gear change update
Bump!1970 ford maverick wrote:x2,MavMan is also curious of the results?,512Fairlane wrote:Tore did you ever get results on the gear change or switching to the 1150? I'm making the switch back to the 2.46 low and I'm running 4.10s.
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» Gear change question
» Pro Stock Trans gear ratio / Rear Gear
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
Page 3 of 3
