Need help with measurements/ Kaase
jonkaase
Need help with measurements/ Kaase Empty Need help with measurements/ Kaase
Post  jonkaase September 7th 2010, 10:05 pm
I need some measurements of older Fords, between the shock towers. This would be at valve cover height. Is the early Mustang the same as a 66-67 Fairlane? Are 65-66 Mustangs the same as 67-68 cars? How about the 64 Fairlane? How about the Fox body cars? Thanks, Kaase
jonkaase
Need help with measurements/ Kaase Empty Re: Need help with measurements/ Kaase
Post  cool40 September 7th 2010, 10:14 pm
fairlane's have more room than a mustang and 65-66 mustangs are smaller than 67-68.the 67-70 mustangs are the same on the towers but 67-68 have a little less room in the firewall/floor pan area for the trans. Smile
Post  bruno September 7th 2010, 10:18 pm
Foxbody -------
34 1/4 total between towers .... 4 1/4 from valve cover to shock tower on Dr. side and 2" from valve cover to shock tower on pass. side .. this is with the Canton Fabbed valve covers and edelbrock rpm heads
http://WWW.CKRME.COM
Post  richter69 September 7th 2010, 10:21 pm
I cut mine out years ago.................I'm no help.............better go make KY a tunnel ram before he goes off the deep end and starts making more graphs............... Laughing
Post  bbf-falcon September 7th 2010, 10:36 pm
cool40 wrote:fairlane's have more room than a mustang and 65-66 mustangs are smaller than 67-68.the 67-70 mustangs are the same on the towers but 67-68 have a little less room in the firewall/floor pan area for the trans. Smile
XXXXXXXXXXXXXXXX22222222222222222222
Need help with measurements/ Kaase Empty Older Fords!
Post  Wheelie58 September 7th 2010, 10:53 pm
Now guys...Jon said "older Fords"
I bet he meant 1958 Fords!
No tape measure needed. Just install the engine. I bet a set of those nice Hemi Boss 9 heads would fill up the area nicely! Cool
Keith
Wheelie58
Wheelie58
Post  res0rli9 September 8th 2010, 12:16 am
Jon, stock 69 MachI 428 cj with stock crome v/c at the widest point of v/c = 26 3/4", at top of header flange 25 1/2" cj, non cj =25 7/8"
70 MachI with stock 71 460 with stock v/c at the widest point of v/c = 26 5/8", at header flange = 25 7/8" , this is a non cj car
#s are between the shock towers
hope this help's. Keith
Post  LivermoreDave September 8th 2010, 7:46 am
1968 Mustang (C code) without engine, or shock tower support is 27 7/8" at top of shock tower and 25 1/2" near the head location of the shock tower. 1967 Mustang shares the same dimensions.
1965 Mustang (A code) with 289 engine and shock tower support in place is 27 1/2" at top of shock tower and approximately 25 to 25 1/2" in the head area. 1966 Mustang shares the same dimensions.
Dave.
LivermoreDave
Post  jasonf September 8th 2010, 9:15 am
In a 64 Falcon at the top of the valve cover (SBF) the shock towers are 26" wide and at the base of the valve cover it is about 21" wide.
Post  bruno September 10th 2010, 6:32 am
Arrow
