if you were going to use a vacuum pump would it be moroso or aerospace?
+9
Wheelie58
TRUKPULR
bigjohn2007
13 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: if you were going to use a vacuum pump would it be moroso or aerospace?
1Bad91 wrote:It looks new but it's about 5 years old now
I bet a new set of rotors and you would be good to go. They are very easy to replace, too.
whatbumper- Posts : 3024
bigjohn2007 wrote:i am spraying nos and it blowing the intake gasket out i have replaced them with gasket maker with a big bead and it still does it and i was told if i had a vacuum pump it would solve my problem.
Have you leaked down the cylinders? I used to blow them out on a 357 and a ton of spray but the rings were toast...
jbozzelle- Posts : 3705
what kind of tools is needed to check to see if the rings are gone and can you run me throw the process so i can understand how to check the rings.thanks
bigjohn2007- BBF CONTRIBUTOR
What about the one C and S sells, it's not expensive.
DaveMcLain- Posts : 399
Page 2 of 2 • 1, 2
» aerospace 3 vane vacuum pump... anybody run one? good piece or not so much?
» Moroso 22642 4 vane vacuum pump SOLD
» Vacuum Pump
» Which vacuum pump?
» Vacuum Pump
Page 2 of 2
