563" P(DD)51 build underway **GOT SOME NUMBERS**
+72
605FOX
ThndrChkn
Tennessee Bullitt
stangr8cr
whitefield
665 falcon
Greg_P
Wayne Pearce
R_Williams
bird of prey
61coon
ToddB
D's557BBF
mustang68mustangs1
QtrWarrior
Tony M
Tore
waypastcrazy
lghting94
hillbillyerv
Larry Williams
23Alt
'65 T-BOLT
Maddmattmustangs
56Tbird
tiger
nuclearcobra
LivermoreDave
342g
Oakley Motorsports
jones
138
DFI429
psfracer
KY JELLY
95lightiningguy
cheatham
4thHorseman
D-CEL
Larry T
Bernie
512Fairlane
TeflonDon
Mark Laczo
67460
72mav
away
hienergy557
TorinoGT
devildog
bb429power
76 posters
Page 25 of 31
Page 25 of 31 • 1 ... 14 ... 24, 25, 26 ... 31
Re: 563" P(DD)51 build underway **GOT SOME NUMBERS**
what was your short times Jon?
342g- BBF CONTRIBUTOR
bruno wrote:
congrats on the numbers Jon ....... someone had just brought up that you would be slower then me , and i actually gave you props saying you should be faster with an n/a engine rather then my nos deal ....sorry i thought you said it was going to do 1000 ....... my bad
It made 954, dyno guy thought it was fat and there was more to get with a highspeed. On the track the temps at the stripe were a good 100* warmer than what it needs to be, I finally got the temps in check but the 6o is a solid tenth and a half off.
I knew the tires were old, and that TVRP starting line sucks, which even ole Ted was off a good bit.
I did get the feel the bump in the left lane at 1000' as I felt the rear tires come off the ground and the datalogger confirms this with a nice 500 rpm spike at that point.
I'm not downing your ride Nick that thing is finally running the numbers a 850 hp plus a power adder car should run.
Bottom line is we are both out making passes trying to go faster and faster. My last pass was against one of the bigtime nitrous locals here, he was running only 1/8 but he stayed in it that run as he doesnt like other cars to come around him, I treed his ass and he put a fender on me and we hung there the whole way, and he aint runnin no little plate system.
342g wrote:what was your short times Jon?
1.53, 1.34, 1.35
when the car went the 5.60 last spring it was with a 1.26, mineshaft air, 4.86 gear and a "liquid torque" M5 tune.
Converter is a bit looser now with the added power, only saw a 900rpm drop on the shift where before it would go 1400
[quote="richter69"]
138- Posts : 1593
of course I got video............. give a brother a little time......I'm wore out lol.
I did pop the chute just for the hell out it.............easy on the brake pads..........
richter69 wrote:of course I got video............. give a brother a little time......I'm wore out lol.
well nick failed at video...and I'm getting the shakes over here... anyway good deal on the times, and most importantly at this point she stayed together.
138- Posts : 1593
Well according to Charlies Handy Dandy pit side scale, you have a bunch left in there, good luck getting it out.
I dont usually get nervous, but man right before I hopped in to take it too the lanes I had the jitters a bit. Once i fired the bitch up all was good, been 6 months, I forgot how hard this thing pulls lol. I'll be bored with it soon............I might need to get a power adder..........
you aint gona get bored,you have hooken issues to deal with.richter69 wrote:I dont usually get nervous, but man right before I hopped in to take it too the lanes I had the jitters a bit. Once i fired the bitch up all was good, been 6 months, I forgot how hard this thing pulls lol. I'll be bored with it soon............I might need to get a power adder..........
before..
after....
thanks...
after....
thanks...
138- Posts : 1593
nice work Jon!
'65 T-BOLT- Posts : 1464
39 nozzel and dropped the 2 step to 3800
Looks good Jon. Get that thing to hook and it's really going to haul.
512Fairlane- Posts : 694
last run, smaller pill, 4000 leave, worse 60', wanted to move around a bit but managable lol.
richter69 wrote:last run, smaller pill, 4000 leave, worse 60', wanted to move around a bit but managable lol.
It has a bounce in it Like BOO BOO' s did on the leave.
sounds damn good Jon! it realy looks stiff in the back,like it aint hit'n the tire hard.what air psi you run?
the sidewalls are not stiff, no tubes, and they are already hammered from last year. I'll get with Oakley and get some new kicks on the way. I lowered the back end and just like last time it I did it it didnt like it, puts the ladder bar pointing down too far so thats some of it.
I got enough data that I see what I need to work on.
first pass was 11.5 psi, 2nd 11, and the last was 10.5............and it did walk around a good bit that time.
richter69 wrote:................... I'll get the gears moved around and get after the 1/8th mile program now...........................138 wrote:what did it run a best last year?
So your getting ready for the Bash?
jbozzelle- Posts : 3705
i'm sure you have adj shocks,did you move them any?the strange shocks i got last fall sure work good.did it want to drive to the right a little? it kinda looked like it left and pulled to the right?IMO,looken at video.richter69 wrote:the sidewalls are not stiff, no tubes, and they are already hammered from last year. I'll get with Oakley and get some new kicks on the way. I lowered the back end and just like last time it I did it it didnt like it, puts the ladder bar pointing down too far so thats some of it.
They are on the stiff side IIRC, just messed with the fuel system trying to sort it out some, my dyno session did not prove to be any help in the tuning dept lol.
Might need to put a mix of hygard in the tranny lol.
does a mean jon force burnout lol. It almost looks like the shocks are bottoming out.
KY JELLY- Posts : 1530
tire temps were in the 180 range, a bit warm, lots of wheelspeed on a highgear burnout lol.
Car has always had the bounce in the rear with a softwall slick. do need to play with the reqar shocks some, the fronts are non adj so they are what they are.
Fire the camera man, needs to put camera on the tire sidewall on the launch, couldn't tell if it was wadding or not.
» 460 build underway-New here and new to 460
» New build hp numbers?
» No rules BBF nitrous build - Let's build it
Page 25 of 31
