reading plugs at idle ? can it be done.
reading plugs at idle ? can it be done. Empty reading plugs at idle ? can it be done.
Post  89lxcoupe September 20th 2010, 5:05 pm
hey guys i always hear about reading your plugs after a wide open pass or a 2nd gear pull, well what about at idle, i have installed a wide band gauge and have got my idle afr to about 13.4:1 but has had it as lean as 14.1:1 and i am still getting my plugs sooty on the porcelain !
89lxcoupe
reading plugs at idle ? can it be done. Empty Re: reading plugs at idle ? can it be done.
Post  johndickjr September 20th 2010, 5:23 pm
http://www.dragstuff.com/techarticles/how-to-read-plugs.html
johndickjr
Post  dfree383 September 20th 2010, 10:11 pm
What carb? What application? What fuel? How are you tuning it? What timing? What ignition? What plugs? What compression? What heads? Etc???
Post  89lxcoupe September 22nd 2010, 1:44 pm
dfree383 wrote:What carb? What application? What fuel? How are you tuning it? What timing? What ignition? What plugs? What compression? What heads? Etc???
since you asked.
holley 750 3310 6.5 power valve in front block 72 jets fronts 84 jets rear i have about 9 inches of manifold vacuum
93 oct
tuning via wideband idle air screws and holley jet kit
34 total locked
msd ingition with stock replacement tfi coil
autolights 124's
10.5:1 compression
c8ve heads ported stock valves
89lxcoupe
