Reading spark plugs
hotrodbird
Reading spark plugs
Photos is #1 plug, 2-8 look very similar. This is a mix of 93 octane pump and 110 Rengade fuel.
How much leaner do you think I can go?
545 w/ TFS heads 12.25:1 CR 30* timing locked out. Thanks for any input!
hotrodbird- Posts : 8
Re: Reading spark plugs
is that one pass ? did you idle it around the pits ? or is this a street car with multiple miles ?
Street driving, 22 miles most of it highway @ 2600 rpm... two runs up to 6,500 rpm.
It looks good for street driving. I wouldnt go leaner
whatbumper- Posts : 3024
Thanks for the replies guys. This is the stongest engine I've had in the car so far and want to get as much out of it as I can without hurting it.
Thanks, I'll do that and try to post it this evening if I can.
color looks good for street driving, hard to get a good read on the timing mark.
I agree with Lem, need a better view from the side. From this angle the ground strap looks to be a little on the warm side.
Get a AF meter, the pump gas is almost impossible to read. The driving and Idlin around make it hard too. Make a full pass and shut it off and check them.
Thanks for the advice, I'll leave it as is, A/F monitoring guages seem to be getting more and more popular but I think a TFS Mafia intake is next on the shopping list...
i would guess you are pretty conservative at 30degrees, i would think 34 is more favorable
cooter- Posts : 220
» Reading spark plugs
» Sparkplug advice
» Reading Plugs
» Spark plug fuel ring reading
» reading plugs at idle ? can it be done.
» Sparkplug advice
» Reading Plugs
