806 cubic inches ........
+19
Havaneiss Dei
away
56Tbird
605FOX
138
bb429power
James Hahn
'65 T-BOLT
Outlaw5.0
ThndrChkn
fastford600
1Bad91
23 posters
806 cubic inches ........ Empty 806 cubic inches ........
Post  bruno October 11th 2010, 10:49 pm
wow an 6.00 arm with an A460 block
http://www.rpmmachine.com/ford-460-806-stroker.shtml
http://WWW.CKRME.COM
806 cubic inches ........ Empty Re: 806 cubic inches ........
Post  1Bad91 October 11th 2010, 10:58 pm
make it pump gas friendly....lol....man that would be a monster
1Bad91
1Bad91
Post  Curt October 11th 2010, 11:00 pm
I think that will put the pin just under a 1/2" above the valve reliefs. :/
Post  Nevs October 11th 2010, 11:02 pm
I'd like to see that done in a 10.32" deck block.................
Post  Curt October 11th 2010, 11:04 pm
At least you wouldnt have to worry about the pin being in the ring pack. haha
You would need a custom chamber though pirat
Post  Lem Evans October 11th 2010, 11:04 pm
Nevs wrote:I'd like to see that done in a 10.32" deck block.................
Seems that is the case.........seems somebody wants some action on the forum Rolling Eyes
Post  fastford600 October 11th 2010, 11:06 pm
will that even clear the block? because my 4.5 stroke looks a little tight.
fastford600
fastford600
Post  Curt October 11th 2010, 11:08 pm
A 7.750 rod on a 6" stroke will put the pin .43 out of the hole
Post  bruno October 11th 2010, 11:41 pm
Laughing
Post  bruno October 11th 2010, 11:49 pm
does FRPP still offer the a96 in the 12" deck deal ?
Post  Nevs October 12th 2010, 6:32 am
bruno wrote:does FRPP still offer the a96 in the 12" deck deal ?
Not that I'm aware of, I believe C&C bought the rights to the design, but I could be wrong.
Post  ThndrChkn October 12th 2010, 9:43 am
fastford600 wrote:will that even clear the block? because my 4.5 stroke looks a little tight.
If I'm reading it right, that's what they're claiming. Shocked Shocked
Doug... Cool
ThndrChkn
ThndrChkn
Post  Lem Evans October 12th 2010, 9:58 am
FRPP only had a part # [A96] on the 10.320" block.
Post  dfree383 October 12th 2010, 10:07 am
They failed to mention the 2" deck plates, Sleeves and massive amount of clearancing required..... oooop's !!! Some one needs to call them and order a complete assembled short block with those specs and see what happens.... Laughing
Post  Outlaw5.0 October 12th 2010, 12:44 pm
dfree383 wrote:They failed to mention the 2" deck plates, Sleeves and massive amount of clearancing required..... oooop's !!! Some one needs to call them and order a complete assembled short block with those specs and see what happens.... Laughing
Yep, I did the math with the 10.320 deck, subtact half the stroke(3.00), subtract the rod length(7.75), you get -.430, pretty tough get the pine in that location.
Outlaw5.0
Post  '65 T-BOLT October 12th 2010, 5:11 pm
I think Nick want more cubes!!!!
'65 T-BOLT
'65 T-BOLT
Post  bruno October 12th 2010, 6:26 pm
'65 T-BOLT wrote:I think Nick want more cubes!!!!
definetly not ....... i was just browsing the good ole internet and came across this fairy tale and did some more research and just dont understand how a business can advertise such false statements ..... most guys talking about heavy grinding with a 4.75" arm let alone a 6" deal ...thats all just curious
Post  James Hahn October 17th 2010, 8:35 pm
yea i didnt see any 2'' deck plates or sleeves in the pic.... better off getting a bigger block!!
James Hahn
Post  bb429power October 17th 2010, 8:36 pm
Is there a way to add 2" deck plates? confused
bb429power
bb429power
Post  138 October 17th 2010, 9:34 pm
I imagine it would take more than just deck plates...pirat
806 cubic inches ........ 694cibuild0013
138
Post  605FOX October 17th 2010, 9:38 pm
great honing job on those plates
605FOX
Post  56Tbird October 17th 2010, 9:39 pm
10,000RPM should be no problem with this set up Basketball lol! king
56Tbird
56Tbird
Post  away October 29th 2010, 10:08 am
56Tbird wrote:10,000RPM should be no problem with this set up Basketball lol! king
At this rate just increase the compression to around 24:1 and we will be able to get it done under 4,000 RPM ........add a turbo and we'll have a diesel 385 series Big Ford LOL Exclamation
away
away
Post  whatbumper October 29th 2010, 12:35 pm
hmmm that is an idea Cool
Post  richter69 October 29th 2010, 12:55 pm
24-1 is too much even for a diesel using a turbo...............but some will argue that but yes you can have too much static compression in one lol.
