Vacuum Pump Check
Vacuum Pump Check Empty Vacuum Pump Check
Post  onequickstang October 16th 2010, 9:17 pm
Hello all,
I installed a vacuum pump and now I want to check to see how much vacuum it's pulling. how and where do I hook up a vacuum gauge? How do I know how much vacuum is best for my engine. Do I check it on a dyno?
Thanks in advance,
Rob
onequickstang
Vacuum Pump Check Empty Re: Vacuum Pump Check
Post  Bret Powell October 16th 2010, 11:03 pm
There should be no crankcase ventilation anywhere. Make an adapter from a PCV hole or something similar on your valvecover, attach the vacuum gauge. Never run more than 10" vaccum on a BBF. You may need a release valve something similar to what Moroso sells.
And yes it is best to setup on a dyno.
There it is in a nutshell! Bret
Bret Powell
Post  onequickstang October 17th 2010, 10:33 am
Thanks bret. Yes, I do have the relief valve on the other valve cover so I can adjust it. I've heard the stories of what could happen if you run more than 10" on a BBF. What if the engine makes more power with more than 10"? Is there something I can change that will help it live longer if I do run more than 10"?
Thanks again,
Rob
onequickstang
Post  onequickstang October 17th 2010, 11:38 am
One last question... at what RPM do you check the reading? I'm guessing in the upper range as if you were running at the track?
Thanks!
onequickstang
