Lightweight flywheel vs standard weight?
Lightweight flywheel vs standard weight? Empty Lightweight flywheel vs standard weight?
Post  Maddmattmustangs October 18th 2010, 9:20 am
What are the pros and cons between the two???
Maddmattmustangs
Maddmattmustangs
Lightweight flywheel vs standard weight? Empty Re: Lightweight flywheel vs standard weight?
Post  dfree383 October 18th 2010, 9:30 am
depends on what your doing with it, Street Car? Drag car? Road Race?
Post  Maddmattmustangs October 18th 2010, 12:48 pm
Street strip, I hear it's easier on the crank and helps the motor rev faster
Maddmattmustangs
Maddmattmustangs
Post  TravisRice October 22nd 2010, 8:50 pm
Matt,
Depends on the weight of the said car too. A Heavy flywheel will work better in a heavy car if you want to rpm it to leave. It will shock the tires and not bog down the engine, the theory of momentum . A light flywheel can have the opposite effect in a heavy vehicle, yet really make a lighter car react better. A heavy flywheel will also sound sluggish and drawn out, light will sound crisp, clean and fast.
JMO
Travis
Post  Maddmattmustangs October 25th 2010, 11:29 am
so with a 3400 lb car i probably should be looking into a heavy flywheel?
Maddmattmustangs
Maddmattmustangs
Post  dfree383 October 25th 2010, 11:36 am
not necessarily, I wouldn't look for a monster heavy on, Just stick with the mid weight billet race stuff and stay away from the real light aluminum stuff. For a Cleveland stick in the 25# range.
Post  TravisRice October 25th 2010, 8:46 pm
dfree383 wrote:not necessarily, I wouldn't look for a monster heavy on, Just stick with the mid weight billet race stuff and stay away from the real light aluminum stuff. For a Cleveland stick in the 25# range.
Daves right.
I used the extreme to make my point. Heavy car, little engine .............ex. Full size car with a small block ............heavy flywheel. You get the jist now.
Travis
Post  Maddmattmustangs October 25th 2010, 10:57 pm
Yup! And for a big block I could get away with a lighter flywheel
Maddmattmustangs
Maddmattmustangs
