Are there different harmonic balancers for 429/460
Does the 429/460 have only one balancer available? Or is there a 3 and 4 bolt like the small block. If so when were each used?
Re: Are there different harmonic balancers for 429/460
The FRPP units have both ..3 and 4 bolt patterns.
The very old 429 engines and maybe also the 460 had a balancer with belt grooves cut into it's circumference. It was made similar to a 300 6 cylinder balancer in that way. The spacer used behind it is also unique. After about 1970 they changed and I think that they are all the same.
Doesn't the Ford racing piece have two patterns so that it can also be used on an FE engine?
DaveMcLain- Posts : 399
my ford steel balancer has dual bolt pattern
cooter- Posts : 220
» harmonic balancer
» harmonic blanacer?
» SFI Flywheel and Harmonic balancer ?
» Harmonic Damper opinions
» Harmonic balancer
» Harmonic balancer
