Crank adapter question
Can anyone using one or a person that knows, tell me if the Crank shaft adapter is needed when running a PG and midplate kit from TCI. I am having problems and before I go purchase a new plate, I need to know if it is used or needs to be used. Obviously I am having starter clearance problems. Before you ask, the car came this way. Thank you fellow keepers of the knowledge.
Dustin
Dustin
biddy84- Posts : 42
Re: Crank adapter question
You will need to use the crank adapter. It keeps the converter centered in the end of the crank. There is one other possibility. You could have a custom converter made. Powerglide, but have them put Ford pilot on the end for the crank and also extend the pilot by the thickness of the adapter plate.
What starter are you using? I have an adapter plate and don't have any starter clearance issues.
I use a hamberger starter. I needed to see if others are using the plate and adapter. I have the PG with turbo input shaft. I don't use an adapter.
I may just buy the ATI plate. I think I screwed up the plate somehow (just not thinking before it was welded).
Dustin
Dustin
biddy84- Posts : 42
Biddy,
My engine is out, if you want to come look at the Plate and Glide converter
FALCON
PM sent.
Biddy
PM sent.
Biddy
biddy84- Posts : 42
I had a TCI in my first dragster and never did get the starter right. THey have hub that was bolted to the fly wheel and use a small collar that went in the crank as well. So on the new car I got the ATI deal and have been way more pleased. You should be able to use any powerglide converter and not have to worry about spacing as they send you 1/2" spacers as well.
Ace
Ace
powerstrokeace- Posts : 1496
Good luck Biddy, and keep us posted.
» crank spacer seal question
» Crank Damper Thread Question
» older style msd crank trigger question
» crank length question
» Crank balancing. Question ?
