TURN KEY DRAGSTER
TURN KEY DRAGSTER
1998 undercover dragster. advanced et certified 23" cage,9 inch mark williams modular aluminum rear end,mark williams brakes,msd 7al3 ignition, bionda mega 450 delay box weld wheels 16x16 rear, top fuel front tires,painless wiring , yellow powder ,coated chassis,598 cubic inches A-460 block 4.600 bore with roller cam bearings(4 bolt mains) motorsport C heads with jesel rockers and titanium valves. 2.400 intake, 1.88 exhaust, motorsport intake manifold, APD alky dominator carb., crower 4.500 stroke BILLET crankshaft, crower steel rods 6.800 long, ross gas ported pistons, danny bee belt drive, moroso pro pan kaase oil pump. only 16 runs on new crank , rods, valve springs. fresh engine runs , jw ultraglide powerglide with 1.80 straight cut gear set trans specialties spragless convertor runs 4.70's at 146mph in the eight mile at 2050 lbs without nos. 32,500.00 937 298 0503
bdkfs- Posts : 26
» C6 won’t turn
» When to turn on the NOS?
» turn up the volume ....
» 611 ci, 9000 rpm. Turn it up!
» WTB Turn signal switch
