gear ratios
+11
knrclark
bcr466
valleydawg
MsKYMustang
KY JELLY
15 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: gear ratios
Seems you are the boss of/if the conv locks up good in high gear.....again......my bad.KY JELLY wrote:Lem Evans wrote:What's that gotta do with finish line rpm?
the engine is the boss on whether the rpm is right or not at a 1000' it seems happy with 4:86. It takes 1.83 seconds from 330- 660 and 1.61 seconds from 660-1000.
Re: gear ratios
no I am not trying to be sarcastic but I would think less strain on the converter would lock it up quicker just my opinion
KY JELLY- Posts : 1530
Re: gear ratios
It's ......being the conv. needs to lock up better i.m.o.
My last words be them right or wrong.
#6 water line kind of a deal.
Re: gear ratios
Have you worked up the slip % on the converter?
Re: gear ratios
What formula do you use Jon one that averages the entire run or actual engine/ driveshat rpm to feet per second ?
I had a long talk with ptc and there is a set tire diameter for what a 4.86 gear is "really" supposed to based off . They seem to think stay with the 4.86 and that there is not any converter problem I think what we came up with was around 6-8% slippage.
Lem I am not afraid to say you told me so , #6 water line or fuel pump ?
I appreciate it Travis and might take you up on it , but I am probabaly gonna try the 5:13
Re: gear ratios
Most just look at the trap rpm, I know when I'm geared for the 1/4 the slippage at the 1/4 mile trap is in the 4% range. The 1/8th trap % is much higher. It depends a lot on the stator design, degree of the "windows" etc...............how aggressive the converter is.
A guy could test a pile of converter and gear combo's to get it perfect, I rekon "perfect" depends on what your after........................
Re: gear ratios
call Lenny
res0rli9- BBF CONTRIBUTOR
Re: gear ratios
I am not opposed to calling anyone and I might just do it
You have math and you have the real world facts (time slip) as far as car performance is concerned.
To me and the real world passes I have personally seen from my car and my competitors ,the only #'s that do not match within reason are my 60 times. My 60 times are way quicker than they should be and that's comparing to other cars and you can even try the famous wallace caculator . http://www.wallaceracing.com/etcalc.php
The car has 330' 3.22-3.25 , et 5.03 -5.10 mph from 135 -138 mph .
I have got several 60 times at 1.07, 1.08, and one 1.05. I don't think anyone could argue that it takes well over 1030 hp to produce 1.0 60' times at 2400lbs and My engine is not making that much power by a long shot so either the converter is multiplying torque from m-5 fumes or something is going on.
here is a qualifying sheet from one of our races
Duck is running a 706 cid , the rest of the 140 mph cars are blown and the rest except mine are spraying nos
Re: gear ratios
Getting out run on the top.... not enough wind in the motor, just not making the HP to go that fast.
But yourmaking a boat ass load of torque.....
Re: gear ratios
Can you get rid of 200 lbs somewhere?
Curt- Posts : 2791
Re: gear ratios
Time to trade your knife for a gun IMO, and I dont think gears, converters, M5, S10 pumps, green oil, highspeeds, nano-domes etc is gonna be enough to get it done.
Re: gear ratios
now Fabio we all know a little squirt of giggle gas would do it .
Re: gear ratios
then what are you waiting for?
Re: gear ratios
Lem Evans wrote: A small block gear in that package? I'd guess I'm missing something.
Hell Lem, we run 3.50's with our small block turd (low 1.20's sixty foot on a 29.5x10.5 tire). I pretty much live in the small block world and I don't know anyone running the gear ratios I read on this site, big blocks or small blocks. and I am talking 4.80-5.30 3000lb cars. some of them even NA.
whatbumper- Posts : 3024
Re: gear ratios
If all gear ratios are based on about a 26-27" OD tire, then it makes sense that a car with a taller OD tire could need/use a steeper gear ratio than what is thought of as the "norm" and still be in the correct RPM range for a given engine combo.
DILLIGASDAVE- Posts : 2262
Re: gear ratios
we run a 5.00 in the brown turd, but its only a 28" tire lol
Re: gear ratios
whatbumper wrote:Lem Evans wrote: A small block gear in that package? I'd guess I'm missing something.
A small tire with a heavy car and lots of power will not tolerate the torque load a big tire and a light car will. An efficient launch will get up on the tire quick and most times slip the tire just a bit.
You are just gaining most of your acceleration on the other half of the track because your tires would literally bounce off the track if you threw all of the torque multiplication to them off the line whether it be through gearing or high stall speed.
Re: gear ratios
anyone interested this is what Marty Chance had to say
Marty Chance
Post subject: Re: Marty can I get your opinion
PostPosted: Wed Jan 19, 2011 8:14 am
Offline
User avatar
sound like the combo is pretty close. do you know what the rpm drop is on the shift? The 5.13 gear may help it accelerate better especially in high gear where the spragless will hold back the engine rpm rate and may help the launch be more consistant by allowing you to leave from a lower rpm chip
Neal Chance Racing Converters
Home of the World's Fastest Automatic Doorslammers!
www.racingconverters.com
Marty Chance
Offline
User avatar
Re: gear ratios
Again you'll just have to try it, honestly I dont think the 5.14 will help much if any. And the spragless does explain some of the et and mph loss on down track.
You can play the numbers all you want, but the timeslip will be the final say if it works or not.
Re: gear ratios
What et loss are you speaking of ? The mph and et are very close to what they should be.
Does it not seem strange to you that an alcohol engine of this size would like the rpm this one does ? Who knows why, it might be Lem's cam , Charlie and Laws port job , the tfs intake manifold , but it does not drop hp very quickly at all above 7000rpm it keeps on accelerating.
You are right the et slip tells the tail and every move I have made with this engine it says "I want to be turned in my upper rpm range"
The converter and gear has got to coincide with where the engine accelerates the quickest, if the chassis and tires will handle it , it will run quicker. It does not matter what you think or I think.
Re: gear ratios
my old motor liked rpm, so I see no reason this one wont...again trial and error lol.
A spragless converter will eat up some et and mph over a sprag type, more of a topend deal.
Re: gear ratios
so.....when are the new gears gona be in?KY JELLY wrote:What et loss are you speaking of ? The mph and et are very close to what they should be.
Page 2 of 2 • 1, 2
» gear ratios.
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
Page 2 of 2
