a question about a 7.3l power stroke
a question about a 7.3l power stroke Empty a question about a 7.3l power stroke
Post  bigunitmudracing January 28th 2011, 12:58 pm
My work truck isn't running right its a7.3l power stroke.. so i checked it out and did a compression check.. #8 has 130 compression.. min is 250.. so i pumped air into the cyl and it comes out of the cranks case..
Has anyone heard what is common on these trucks 96 ford f350
My guess is rings are bad, pistons cracked or has a hole in it, cylnder cracked maybe....???
Thanks..
Getting ready to pull it out!
bigunitmudracing
bigunitmudracing
a question about a 7.3l power stroke Empty Re: a question about a 7.3l power stroke
Post  richter69 January 28th 2011, 1:04 pm
Airbox prolly broken or the inlet tube, look at the edges of the compressor wheel..................if its dusted you'll see it.
You gotta pull it out and rebuild/fix that hole. This is a case where the engine is not to blame but rather the shitty airbox FORD designed and put on it.
Post  bigunitmudracing January 28th 2011, 6:08 pm
it has a k&n intake system on it....
but its still possible.. just got the truck a couple months ago.. not sure what they did!
bigunitmudracing
bigunitmudracing
Post  richter69 January 28th 2011, 7:59 pm
the stock junk box is better than the k and n.......................after you fix the motor pour a can of gas on the k and n and set it on fire.
The AIS setup Ford sells is awesome.
Post  bb429power January 28th 2011, 9:44 pm
richter69 wrote:the stock junk box is better than the k and n.......................after you fix the motor pour a can of gas on the k and n and set it on fire.
NEVER use gas to start a fire, you should know that...Goes BOOM in your face then you don't have to shave your beard:lol:
bb429power
bb429power
Post  Larry T January 28th 2011, 9:46 pm
AIS info........ Smile
http://www.superdutypsd.com/ais.php
Larry T
Larry T
Post  342g January 28th 2011, 10:37 pm
What air system do you recomend Jon?
342g
342g
Post  richter69 January 28th 2011, 11:57 pm
the link above you............with a fender mod................ Wink
Post  bigunitmudracing January 31st 2011, 1:13 pm
Its a 96 , that kits superduty?
bigunitmudracing
bigunitmudracing
