Engine oil weight
Engine oil weight
What are the things a person needs to look for when picking out a synthetic oil wieght for your particular build?
Mine- street/strip.
521 cu in. 10-1
small roller
FRPP SCJ heads
Hyflow Dynamics oil pump, stage 1 oil mods.
Motor has great oil pressure now with half 30 wt. and half break-in oil, just need a recommendation what to change to.
Dave
Mine- street/strip.
521 cu in. 10-1
small roller
FRPP SCJ heads
Dave
NO FAIR- Posts : 138
Re: Engine oil weight
Thanks Lem,
I will review my notes and check what my clearences were. Does it matter on the ring gap clearences at all?
Dave.
Dave.
» ENGINE RPM DROPS & ENGINE DIES AT IDLE & BRAKE PROBLEMS
» Engine Oil & Transmission Weight - Street Motor
» Boat engine carb convert to drag engine
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
