lunati voodoo 61602 can it pull 15 vacuum at 900 rpm??
lunati voodoo 61602 can it pull 15 vacuum at 900 rpm?? Empty lunati voodoo 61602 can it pull 15 vacuum at 900 rpm??
Post  bigunitmudracing April 6th 2011, 12:55 am
lunati voodoo 61602 can it pull 15 vacuum at 900 rpm?? on a stock dive lowerend and c9ve heads stock??
bigunitmudracing
bigunitmudracing
lunati voodoo 61602 can it pull 15 vacuum at 900 rpm?? Empty Re: lunati voodoo 61602 can it pull 15 vacuum at 900 rpm??
Post  rmcomprandy April 6th 2011, 10:34 am
With creative use of vacuum advance and the mechanical advance curve it may ... won't fit into a stock headed engine without some guide machining or long valves.
Post  hookin78 April 6th 2011, 11:03 am
depends on your compression.... I pulled 15 at 850 rpm with a 61603 voodoo.... for a couple years 10.8 to one..... locked out distributer 33 deg timing......
hookin78
Post  tiger April 6th 2011, 11:18 am
Mine pulled 17 1/2 at 900 rpm. It was a 472 with c8 heads 2.2 and 1.76 valves, flattop pistons. Heads were fully ported with cj intake ports and scj intake with 950 Holley dp.
tiger
