New bullet 1003 hp 810 tq P51
+55
AZFairlane
Tore
michealj
1970 ford maverick
Moodyblues
605FOX
fox331
bb429power
KY JELLY
devildog
Filucky
peganit2
knrclark
hienergy557
D's557BBF
psfracer
zbob
Mark Laczo
BB94STANG
D. Sea
lghting94
whitefield
bigblockfox468
138
342g
61coon
David Willingham
stangr8cr
Race Ready Fabrications
Tennessee Bullitt
56Tbird
ThndrChkn
512Fairlane
FORDMUD
'65 T-BOLT
59 posters
Page 6 of 17
Page 6 of 17 • 1 ... 5, 6, 7 ... 11 ... 17
Re: New bullet 1003 hp 810 tq P51
They are correct per the application.BigBlockRanger wrote:are those a/f ratios right?
I don't have a whole lot of experience, but do those seem a little on the lean side?
This is real gas not pump swill which needs to be richer.
IDT-572 wrote:Sorry if I didn't get to everybody yesterday on the phone, but I was very busy in the dyno cell. I didn't make any out going but a couple of out going calls.
Dave Freelander will post the dyno sheet for me here in a little bit.
The engine is wet , the rings never took a seat the best vacuum we saw was 4 lb's @7200.
It made 1003 hp @7200 and 810 Tq @ 6100 rpm. I don't think if gave up much torque to get the hp.
Over 800 ft lb from 5600 to 6400 rpm.
Hats off to Lem and Phillip Oakley, for sticking with me and helping tune the engine. They both have unbelievable tuning skills , such a wealth of knowledge.
I cant wait to get it in the car.
Wow! Very impressive. Makes me want to throw more carb and port the heads next time around. Your torque is 28 ft-lbs higher then mine AND 1000 rpm higher! And, like you mentioned, it was only pulling 4lbs of vacuum---and not the best conditions either. Awesome job to everyone involved!
IDT-572 wrote:dfree383 wrote:First Known N/A Gas P51 Engine to 1000 HP !!!!! Congrats Blake !!!
That is a miss print on the carb size, it was a QFX 1250 Quick fuel I just noticed it................
Blake ... is that really 4 negative POUNDS like everyone keeps saying or is it Inches of Mercury vacuum ?
congrats on your deal Blake! I spent the last hour reading this post. Those are some mighty fine numbers there big guy. Can't wait to see some track numbers
D's557BBF- Posts : 1186
Thanks everybody.................
D I hope to get to Bowling green this month and get some numbers .................
IDT-572 wrote:Thanks everybody.................
Bring yo Laptop and we will setup a LIVE VIDEO STREAM
D. Sea- Posts : 2768
D. Sea wrote:IDT-572 wrote:Thanks everybody.................
If I make it there it will be there......................
IDT-572 wrote:D. Sea wrote:IDT-572 wrote:Thanks everybody.................
WTF is this "IF" crap
D. Sea wrote:IDT-572 wrote:D. Sea wrote:IDT-572 wrote:Thanks everybody.................
Got a ton of work to do.............. I'll make it somehow, heck I want to see THA NICKSTER BLAST OFF..........
IDT-572 wrote:D. Sea wrote:IDT-572 wrote:D. Sea wrote:IDT-572 wrote:Thanks everybody.................
Decided to re-ring the engine, the rings never seated on the dyno. I am afraid I added the Schaeffer oil on the dyno to quick and the rings never took a seat. That was the reason for the low vacuum readings. I thought about just putting regular oil back in with a quart of trans fluid and running it hoping they would seat later.
But a good friend talked me into going on and fixing it right while the engine was out of the car. So it should be long blocked tonight or maybe even completed if the rings arrive today.
Everything looked great in the bottom end............
May have some track times after the 21st .............
It sure is hard to make yourself do that, but you'll be glad you did....I hope it works out good for you Blake.
56Tbird- BBF CONTRIBUTOR
56Tbird wrote:It sure is hard to make yourself do that, but you'll be glad you did....I hope it works out good for you Blake.
Thanks Dan, As much crank case pressure as it had, it would be a pisser if it puked some oil under the tires at a buck fifty before the rings seated
The bore looked good after the new hone job.
damn snake,you better get to it.i'd ring it too.........aw hell you know i'd put it in the car and seat the rings on the road in front of my house! without a window net.
Congrats buddy. Good job. Let's apply some of that Dixie engineering to my 545. What say you Master Po?
738drvr- Posts : 600
738drvr wrote:Congrats buddy. Good job. Let's apply some of that Dixie engineering to my 545. What say you Master Po?
Sounds good Grass Hopper....................
WOW. That is awsome. Good luck
hienergy557- Posts : 179
Nice
Nice build Blake. I hope she performs good for you in the car. Good luck.
Kerry
Kerry
knrclark- BBF CONTRIBUTOR
Thanks guys..............
everything back together?
Waiting on the pan and intake gaskets to get here today. That's all that is left putting the intake and pan on.
Then it's going in the car, and hope it don't pull a Nickster wheel stand...............
IDT-572 wrote:Waiting on the pan and intake gaskets to get here today. That's all that is left putting the intake and pan on.
Nah ... just a Damon wheel stand, lol.
rmcomprandy wrote:IDT-572 wrote:Waiting on the pan and intake gaskets to get here today. That's all that is left putting the intake and pan on.
That will be fine , just don want a spindle busting wheel stand.
» New Bullet or should I say "Revised"
» Well i bit the bullet...
» bullet cam
» Bullet roller cam
» New 604" bullet for the truck
» bullet cam
» Bullet roller cam
Page 6 of 17
