New bullet 1003 hp 810 tq P51
+55
AZFairlane
Tore
michealj
1970 ford maverick
Moodyblues
605FOX
fox331
bb429power
KY JELLY
devildog
Filucky
peganit2
knrclark
hienergy557
D's557BBF
psfracer
zbob
Mark Laczo
BB94STANG
D. Sea
lghting94
whitefield
bigblockfox468
138
342g
61coon
David Willingham
stangr8cr
Race Ready Fabrications
Tennessee Bullitt
56Tbird
ThndrChkn
512Fairlane
FORDMUD
'65 T-BOLT
59 posters
Page 8 of 17 Previous  1 ... 5 ... 7, 8, 9 ... 12 ... 17  Next
New bullet 1003 hp 810 tq P51 - Page 8 Empty Re: New bullet 1003 hp 810 tq P51
Post  richter69 June 17th 2011, 10:11 pm
I heard......... Cool
Post  IDT-572 June 18th 2011, 12:44 am
2-3 psi at the top of first and through second. I could tell on the first run it was laying over bad in second. I will fix the problem tomorrow. Cool Cool
Post  bruno June 18th 2011, 8:20 am
KY JELLY wrote:Blake just called he has got a few shake down passes in at the Lawrenceburg dragway this afternoon . He said so far 1.24 60' 5.58 @124 mph.
Blake just sent a text message his fuel pump lost pressure , so that explains the low mph .
damn nice passes off the trailer .....congrats Blake looks like im gonna have to step my game up ..... get the fule fixed and she will be in the 30's
http://WWW.CKRME.COM
Post  Lem Evans June 18th 2011, 9:32 am
Fabio is laying down on the job.........he's supposed to say "Put a toilet on it Exclamation ".
Post  richter69 June 18th 2011, 9:44 am
Lem Evans wrote:Fabio is laying down on the job.........he's supposed to say "Put a toilet on it Exclamation ".
Terminator Exclamation
Besides you gas guys are too hard headed to listen anyway.............Snake don't need no cape..............he gets a HeRo fuel pump on that biotch it will be fly......for a white guy. Wink
Post  Lem Evans June 18th 2011, 9:59 am
I got a 80A-0 seting it the back of the Flex if he needs it Wink
Post  richter69 June 18th 2011, 10:28 am
Lem Evans wrote:I got a 80A-0 seting it the back of the Flex if he needs it Wink
.......and a barrel valve in the glove compartment...... Cool
Post  IDT-572 June 18th 2011, 10:55 am
I think I returned to much back to the tank. I will pinch off the return line and bring the amps up higher on the pump and push more full to the front. I may need a higher flowing regulator too.
Post  rmcomprandy June 18th 2011, 11:02 am
Just curious ... I see very FEW people running mechanicaly injected gasoline so, why is that???
Post  IDT-572 June 18th 2011, 11:11 am
Hell, they can,t tune injected alky, how the hell do you think they could tune gas with half the tuning window................... lol! lol! lol!
Post  IDT-572 June 18th 2011, 11:12 am
Ky and I have discussed it at length, it may happen. Wink
Post  rmcomprandy June 18th 2011, 3:19 pm
IDT-572 wrote:Hell, they can,t tune injected alky, how the hell do you think they could tune gas with half the tuning window................... lol! lol! lol!
That's what I thought but, it was done a lot in the past with gasoline. The GOOD injection guys must be selling stuff instead of racing stuff, lol.
I built a small block Mopar with mechanical stack injection with gasoline on the street and Jim Kinsler had that system almost perfect for cruising around OR racing it.
Post  KY JELLY June 18th 2011, 6:57 pm
I have the gas nozzles and have had mine running on Q -16 in the shop the throttle response is killer on gas too. I adjusted the barrel valve with my egt until the egts got around 700-750 idling. You would think it would not lean out from there , but I don't have the budget to build another engine on what I think because I think wrong too much lol! .
Just from watching a friend of mine that switched to a fuel pump (80a-0 to 80a-1) the same size as mine on alcohol with considerably smaller nozzles (39 v/s 31) than mine I figured he would be way rich , but he is running the same return pill I do 120. I can only guess the smaller nozzles really limit the fuel delivery even with higher pressure.
Its just a matter of getting the nerve to flatt foot it on the track to get a base line to start with Smile
KY JELLY
KY JELLY
Post  rmcomprandy June 18th 2011, 7:04 pm
The first 2,000 RPM after stall will tell you ... after that, without other by-passes, it only gets richer.
Post  KY JELLY June 18th 2011, 7:18 pm
Mine does not move but about 1000 rpm after stall during a run. Would it simply nose over like Blake's did with the fuel pressure issues or hurt something if it leaned out a bit in your opinion ?
KY JELLY
KY JELLY
Post  rmcomprandy June 18th 2011, 11:03 pm
KY JELLY wrote:Mine does not move but about 1000 rpm after stall during a run. Would it simply nose over like Blake's did with the fuel pressure issues or hurt something if it leaned out a bit in your opinion ?
First, check the WOT mixture "loaded" at stall ... if that's OK then get "somewhere" to make it leave as normal as you can but, immediately shut it off when it comes down ... check the mixture again. If that is all OK it will only get richer from there with no pump by-pass as it will gain pressure with rpm, (unless it's not working correctly), so, now on gasoline you will have to work out the maximum pump pressure by-pass and mid rpm and high rpm by-passes. (1/8th mile you probably won't need a mid by-pass).
Remember, unlike alcohol, gasoline loses power when it gets a little rich.
LOTS of pills to get gasoline worked-out right however, when it is, it will fly.
New bullet 1003 hp 810 tq P51 - Page 8 Empty Video added
Post  IDT-572 June 19th 2011, 9:38 pm
Here is a video of one of the Friday nights runs. Sorry about the video quality, first timer on the camera................. Rolling Eyes spinning bad here.
New bullet 1003 hp 810 tq P51 - Page 8 Th_US4361811
Post  61coon June 20th 2011, 6:31 pm
After today, I think snake might need some wheelie bars and a chute.Or we can just repaint the rear bumper every other weekend. affraid affraid affraid
61coon
61coon
New bullet 1003 hp 810 tq P51 - Page 8 Empty Bowling Green test
Post  IDT-572 June 20th 2011, 10:33 pm
Ran at Bowling green today, with Lems help and Zack from Quick Fuel most of the miss is gone. the last pass the power came up and it almost got on the bumper. 1.24 60ft again. It stumbled as the front end was coming back down, I think fuel came out the front bowl vent and flooded it for a bit. It cleared up about time the front tires were about to touch down. It revved clean then to 7000 in first shifted and didn't miss in second either .
I think the next time out it should start to dial in. Cool
Post  cool40 June 20th 2011, 11:49 pm
sounds like your maken it hard on the little blue coupe. Sad i guess the pump issue is fixed. Laughing
Post  bigblockfox468 June 21st 2011, 7:43 am
IDT-572 wrote: most of the miss is gone
This miss, is it the same thing you and I were talking about or is your miss from something else?
bigblockfox468
bigblockfox468
Post  bigblockfox468 June 21st 2011, 7:45 am
IDT-572 wrote: it almost got on the bumper
Shocked Did RED get some video Very Happy
bigblockfox468
bigblockfox468
Post  KY JELLY June 21st 2011, 11:09 am
so what we are gonna have to figure out here is if a "almost scuffed up bumper " or "broken shoddy Dyno" qualifies as the #2 baddest Kaassby headed p-51 in the world.
They still got to break a strange rear end case , break a set of m&m racecar wheelie bars, get all 4 tires off the ground, and spank Bruno's azz to be in the running for #1 lol!
KY JELLY
KY JELLY
Post  IDT-572 June 21st 2011, 11:12 am
Still fuel system delivery problem. Put a set of .150 ti needle and seats in it and helped it. Still has tuning issues also we were sneaking up on.
Post  IDT-572 June 21st 2011, 11:14 am
No.............. I guess it didn't happen Laughing
