break in question
break in question
so when your breaking in a hydrolic cam that is new... should you warm the engine up first or start it, set timing and 2000rpm for 20min....????
i've broke in a few motors but never reall thought about this... what do you think???
bigunitmudracing- Posts : 159
Re: break in question
bigunitmudracing wrote:so when your breaking in a hydrolic cam that is new... should you warm the engine up first or start it, set timing and 2000rpm for 20min....????
The main reason for needing 2,000 or more RPM for breaking-in a flat tappet camshaft is so the oil pressure will be up cinsiderably and the "splash" from the crankcase will help lubricate the cam lobe / lifter face junction.
my question is do you break it in right away or do you warm up the motor first??
bigunitmudracing wrote:my question is do you break it in right away or do you warm up the motor first??
IMMEDIATELY ... !
thanks... off to DO IT!!! break in here we come!
Done!! everything went well , motor got a little hot during breaking.. 230ish during the last 4 min....
normal?
normal?
a little extra heat is normal, just make sure you dont have thermostat issues or lack of radiator cooling capabilities
cooter- Posts : 220
» engine break in question
» break in oil?
» Cam Break In
» Used cam break in.
» break in oil?
» Cam Break In
