Good night of testing
+23
D. Sea
olschoolsteel
Copperhead_Road
D's557BBF
342g
psfracer
scottke
Bsherry
David Willingham
Wheelie58
KY JELLY
27 posters
Page 2 of 5 Previous  1, 2, 3, 4, 5  Next
Good night of testing - Page 2 Empty Re: Good night of testing
Post  rmcomprandy July 24th 2011, 9:46 pm
IDT-572 wrote:
psfracer wrote:
KY JELLY wrote:
Good night of testing - Page 2 Th_11072407
Blake, what was your 1/8th et and mph on this pass?
I think it was a 5.56 @ almost 125mph 1.24 60 ft.
Blake ... am I to presume that the fuel injection experiment isn't going any further...? Or is it...?
Post  Lem Evans July 24th 2011, 10:00 pm
psfracer wrote:I have a 4600 chip in the 7AL2 now, thinking about going higher. It will see 5200 if I put on the transbrake with no chip and floor it for a second. I need to figure out the shocks to, they are strange double adjustables.
Anyway, I don't want to hijack this thread. But Blake obviously has things figured out with a 1.24 60' time. That is awesome.
At 5,200 rpm it is my opinion that the conv. is too tight. I know that you have a dyno sheet that says that the peak tq. is at 5,000 rpm but in my experience I don't see how that could be the case.
At 5,200 rpm your engine makes 769 hp..........it makes 870 hp at 6,000 rpm.......that's where I'd want to be.
Post  richter69 July 24th 2011, 10:02 pm
I think he plans to spray it, for a n/a deal it is too tight, and 3500#s dont make it any easier.
We can jack this thread all we want.............. Wink
Post  Lem Evans July 24th 2011, 10:08 pm
If a guy plans to spray the convertor........then it needs to be sprayed and quit worrying about the car being a slug w/o the spray.
Post  cool40 July 24th 2011, 10:11 pm
richter69 wrote:I think he plans to spray it, for a n/a deal it is too tight, and 3500#s dont make it any easier.
Mr.Frosty! Razz
Post  richter69 July 24th 2011, 10:13 pm
Mr.Frosty! Razz
that gives me an idea
Post  cool40 July 24th 2011, 10:36 pm
Mr.Frosty! Razz
you full of "ideas".FrOsTy HeRo! Razz
Post  IDT-572 July 25th 2011, 9:21 am
I would still like to do a good A B test to see alky verses gas on injection, on a good efficient engine above 7000 rpm, just not enough time, or money................ Rolling Eyes
Post  IDT-572 July 25th 2011, 9:26 am
I I was a mind to spray mine, I would not tighten the converter..............
My converter is going 6000 on the t break, I am leaving now at 3800. 4000 will give a big high wheelie and 4200 will put it on dang near on the bumper.
I am of the same opinion as lem especially with his car being 400 lb heavier. loosen the converter to around 6000 rpm.
Post  bruno July 25th 2011, 11:26 am
your mph seems low on that pass Blake .... why is that ? did you let out before the 1/4 ?
http://WWW.CKRME.COM
Post  IDT-572 July 25th 2011, 11:28 am
bruno wrote:your mph seems low on that pass Blake .... why is that ? did you let out before the 1/4 ?
No I didn't let out, that's all she had............. I don't know why it's low.
Post  richter69 July 25th 2011, 11:30 am
I'm all about the looser converter in his application, if he is gonna spray the converter on a reg basis with a big hit it might be fine where it is...................that is if the mr frosty will get it whewre it needs to be...............but if its mainly a n/a deal then I would pull the converter out for sure.
Post  IDT-572 July 25th 2011, 11:33 am
Wallace calculator says it should be running close to 165 mph.
Post  c.evans July 25th 2011, 11:41 am
Sorry about the Wallace calculator, but I don't believe 165 mph. The Pitside Chart out of the National Dragster says it should be running 156 mph for an 8.75 e.t. If Blake is able to run an 8.76 e.t. @ "only" 152+mph, then IMO that just means he is an overachiever. Once he gets that front end down out of the air, then he'll run 156 mph.
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  richter69 July 25th 2011, 11:45 am
my turd only ran 156 @ 8.77, that was with issues, but still
165 would be gettting into the 8.30 range
Post  IDT-572 July 25th 2011, 11:51 am
richter69 wrote:my turd only ran 156 @ 8.77, that was with issues, but still
What are you geared and what is your tire roll out.
Post  richter69 July 25th 2011, 12:02 pm
same as you brother..................when i made the 1/4 mile passes though it had a little taller tire, but it was only like a 100", and that was at 7680 rpm.
The other night in the 1/8th it went 129 at approx 7175 rpm,............... this converte over 7000 it gets real aggressive with the lock up. current tire is a touch shorter, I think i measure the rollout at 97".
4.29 gear.
IIRC our cars weigh the same, I'm at 3015 w driver attm
Post  Lem Evans July 25th 2011, 12:09 pm
Blake doesn't have the Grande' aero package. Wink
How the air goes under and over a car is a big deal.......I don't know how a 'calculator' can account for that even if he is the Governor of Alabama.
Post  342g July 25th 2011, 12:16 pm
Lem Evans wrote:Blake doesn't have the Grande' aero package. Wink
Very Happy cheers
342g
342g
Post  IDT-572 July 25th 2011, 12:22 pm
richter69 wrote:same as you brother..................when i made the 1/4 mile passes though it had a little taller tire, but it was only like a 100", and that was at 7680 rpm.
4.29 gear.
I don't understand that............. I only turned 7100 through the quarter and only 6500 through the eight.
Yes I am 3000 with me and a full tank of fuel. 13.5 x 29.5 mickey's
Post  IDT-572 July 25th 2011, 12:24 pm
I didn't know George Clinton was the gov of Alabama............. We want tha funk............ gotta have that funk Laughing
Post  Lem Evans July 25th 2011, 12:27 pm
Areo Funkadelic afro
Post  richter69 July 25th 2011, 12:31 pm
Grande' for the win.......... cheers
I have a blocked grill, but it dont make that much diff.
only thing I can figure snake its in the torque converter........I dont know if your is a spragless or not, mine isn't.
Post  IDT-572 July 25th 2011, 12:39 pm
Mine is spragless, but it won't make up that kind of difference between mph and rpm we have. Mine must lock up tight early
Post  D's557BBF July 25th 2011, 1:04 pm
IDT-572 wrote: I didn't know George Clinton was the gov of Alabama............. We want tha funk............ gotta have that funk Laughing
LOL! What cha know about that "ole' school funk" Blake cheers
D's557BBF
D's557BBF
