question about 6049scj heads
I just found that I need different guide plates for these heads, do I need different pushrods also or will the ones I have now work? I had a stock set heads on it. Thanks
stanggt- Posts : 494
Re: question about 6049scj heads
ok,just learned I need pushrods also. anyone know how much longer rods I need over stock length?
you will have to measure them to know for sure just guessing can cost a bunch I would get a push rod checker and check to see what size you need I know without changing heads just changing my cam last winter I had to change my push rods.
Depends on the brand of rocker somewhat. Typically with the rockers I use.........8.800"/9.150"
AND ... if you are using a large camshaft then you might need a different intake notch location in the pistons, also.
the camshaft is a 614/631 solid lift and I am going to order the adjustable pushrod length checker from jegs but still not sure how to figure what angle the rocker arm needs to be to the valve. Is it a 90 degree angle or so the roller is centerd on the valve tip? thanks guys. I hope I dont need to clearence the piston that will suck in the car.rmcomprandy wrote:AND ... if you are using a large camshaft then you might need a different intake notch location in the pistons, also.
1.73 Milodon's who best to get my pushrods from for this set-up. Your name seems to come up alot lem. ThanksLem Evans wrote:Depends on the brand of rocker somewhat. Typically with the rockers I use.........8.800"/9.150"
I know nothing of the milodon rockers.........we do have some of the FRPP 3/8" 8.800/9.150" p. rod kits if that turns out to be what you need.
ok, we'll let ya know. Am I gunna have valve clearence issues with .614/.631 valve lift with these heads? .030 flat top keith black pistonsLem Evans wrote:I know nothing of the milodon rockers.........we do have some of the FRPP 3/8" 8.800/9.150" p. rod kits if that turns out to be what you need.
stanggt wrote:the camshaft is a 614/631 solid lift and I am going to order the adjustable pushrod length checker from jegs but still not sure how to figure what angle the rocker arm needs to be to the valve. Is it a 90 degree angle or so the roller is centerd on the valve tip? thanks guys. I hope I dont need to clearence the piston that will suck in the car.rmcomprandy wrote:AND ... if you are using a large camshaft then you might need a different intake notch location in the pistons, also.
You want to keep the roller in the center of the valve when fully open and closed.
Ok,Thanks69F100 wrote:stanggt wrote:the camshaft is a 614/631 solid lift and I am going to order the adjustable pushrod length checker from jegs but still not sure how to figure what angle the rocker arm needs to be to the valve. Is it a 90 degree angle or so the roller is centerd on the valve tip? thanks guys. I hope I dont need to clearence the piston that will suck in the car.rmcomprandy wrote:AND ... if you are using a large camshaft then you might need a different intake notch location in the pistons, also.
» who runs 6049scj heads on here?
» question about cnc ported heads
» Question on C9VE-A Heads
» quick question about thor heads
» C460 Heads and Intake Question
