need question answered .asap !!! about piston
need question answered .asap !!! about piston  Empty need question answered .asap !!! about piston
Post  5pointslow October 1st 2011, 4:52 pm
there are probe pistons in the forsale section i want ........ .im running dove -c heads with 2.250 intake valves ...the pistons are for scj /p51 valve relief
will these work with my heads yes or no
thanks
5pointslow
5pointslow
need question answered .asap !!! about piston  Empty Re: need question answered .asap !!! about piston
Post  the Coug October 1st 2011, 5:09 pm
not unless you have them notched for stock valve locations....
Post  5pointslow October 1st 2011, 5:11 pm
so the valves on the scj are moved vs the stock location on my dove c heads correct ? am i gonna have tough time getting a good piston for these heads i have ?? those are a good deal
5pointslow
5pointslow
Post  the Coug October 1st 2011, 5:14 pm
if you have a competent machine shop they can notch them
Post  the Coug October 1st 2011, 5:19 pm
check your P.M.s
Post  bbf-falcon October 1st 2011, 7:07 pm
The Dove-C head is a common oem (stock style) head,and possibly the easiestto buy a shelf piston for. Like Coug has said,you could always have the (intake reliefs) recut for the SCJ/P51 pistons and then later if you wanted too step up to those heads you would only need to bolt them on.
