vacuum pump ?
+22
soupbean
Oakley Motorsports
Larry T
yellowhorse7
774 Super Street
David Willingham
racnrick
KY JELLY
Barney
AL Q
56Tbird
26 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: vacuum pump ?
You just have to make them fit basically, your breather tank should be below the pump exhaust. I mounted my breather outside of the radiator support inside my nose.
Re: vacuum pump ?
Bruno,
I would like to add that if you use a vacuum regulator, it's best to put it in the vacuum line going to the engine and not on the engine anywhere. This is what Star Machine told me. All of their pumps have the vacuum regulator built on the pump except the sportsman model. They say if the vacuum relief valve opens and it's on the engine somewhere, oil will be sucked into the pump.
Re: vacuum pump ?
David Willingham wrote:Bruno,
David,
Thank you for the info , this pump that i got has the reg. on the pump itself
Re: vacuum pump ?
Good deal! I haven't order a pump for mine yet. The dyno had it's own pump. Now that I know how it runs with and without, I'm going to wait until I get to the track and get it all ironed out to see if I need the extra power. It may scare the crap out of me like it is!
Re: vacuum pump ?
I just installed a Aerospace pump on mine and the relief is on the pump itself on the intake side. I got pretty lucky where I could just bolt it to the motorplate and used the smallest spacer and it lined up. I'm actually thinking about cutting the mandrel down and re tapping it so I have a little more radiator clearance.bruno wrote:David Willingham wrote:Bruno,
David,
Re: vacuum pump ?
mocking things up ....
Re: vacuum pump ?
bruno wrote:mocking things up ....
Love the tape on the heads, lol
yellowhorse7- Posts : 1382
Re: vacuum pump ?
Tnat looks like it should work fine. After you get the mandrel on you can use aluminum bushings to get pulley alignment. Looks good. Does your alternator go on the same side? I would try to lower the tank a tad, but that's up to you. Don't forget to take the tape off those super secret heads before you run it, I would hat to see it catch fire, or be hard to remove after you've cooked it on...bruno wrote:mocking things up ....
Re: vacuum pump ?
whats the price on that pump deal?
Larry T- Posts : 1076
Re: vacuum pump ?
Larry T wrote:whats the price on that pump deal?
give Phillip a call so he can discuss all the details , his # is scrolling across the home page
Re: vacuum pump ?
Don't take that tape off Nick,from what i've been told,there's a good chance it could scatter and the tape will hold the pieces together.
Re: vacuum pump ?
Maybe their D0VES...yellowhorse7 wrote:bruno wrote:mocking things up ....
Re: vacuum pump ?
bbf-falcon wrote:Don't take that tape off Nick,from what i've been told,there's a good chance it could scatter and the tape will hold the pieces together.
thxs rick
Re: vacuum pump ?
Barney wrote:Maybe their D0VES...yellowhorse7 wrote:bruno wrote:mocking things up ....
just trying to keep things clean , getting ready for the photo shoot
Re: vacuum pump ?
It looks good, I like the pump, it's nice and small.bruno wrote:Barney wrote:Maybe their D0VES...yellowhorse7 wrote:bruno wrote:mocking things up ....
Re: vacuum pump ?
bruno wrote:bbf-falcon wrote:Don't take that tape off Nick,from what i've been told,there's a good chance it could scatter and the tape will hold the pieces together.
thxs rick
Just razzin a little Nick, it's lookin good.
Re: vacuum pump ?
bbf-falcon wrote:bruno wrote:bbf-falcon wrote:Don't take that tape off Nick,from what i've been told,there's a good chance it could scatter and the tape will hold the pieces together.
thxs rick
i completely understand rick
Re: vacuum pump ?
That's what she said!! Looks Fancy NickyBarney wrote:It looks good, I like the pump, it's nice and small.bruno wrote:Barney wrote:Maybe their D0VES...yellowhorse7 wrote:bruno wrote:mocking things up ....
56Tbird- BBF CONTRIBUTOR
Re: vacuum pump ?
so i recieved the custom one off peterson mandrel and it is a work of art , i will post pictures this evening
Re: vacuum pump ?
it has 2" of vacuum @ 1200 rpm , 6" @ 4000 rpm , 9" @ 6500 rpm .....i think i will leave it set there
Re: vacuum pump ?
Re: vacuum pump ?
Nice Nick! I tried to order one from Phillip today, but I couldn't get him. He must be on vacation or busy. Gonna try again tomorrow. I'm going to get the ProMod pump...I want one that really sucks!
Re: vacuum pump ?
Nick i'll swap that junk pump you have for my nice 3yr old moroso next week when you get here.
Re: vacuum pump ?
David Willingham wrote:Nice Nick! I tried to order one from Phillip today, but I couldn't get him. He must be on vacation or busy. Gonna try again tomorrow. I'm going to get the ProMod pump...I want one that really sucks!
David,
I got to talk to him last night and he is swamped with work. Did you leave a message? If you did he will call you.
» vacuum pump!
» when do you use a vacuum pump?
» vacuum pump ?
» Vacuum Pump
» vacuum pump!
» vacuum pump ?
» Vacuum Pump
Page 3 of 4
