vacuum pump ?
+22
soupbean
Oakley Motorsports
Larry T
yellowhorse7
774 Super Street
David Willingham
racnrick
KY JELLY
Barney
AL Q
56Tbird
26 posters
Page 4 of 4
Page 4 of 4 • 1, 2, 3, 4
Re: vacuum pump ?
IDT-572 wrote:David Willingham wrote:Nice Nick! I tried to order one from Phillip today, but I couldn't get him. He must be on vacation or busy. Gonna try again tomorrow. I'm going to get the ProMod pump...I want one that really sucks!
David,
I got to talk to him last night and he is swamped with work. Did you leave a message? If you did he will call you.
got the message to phillip , had to order some nitro
Re: vacuum pump ?
thanks guys we got David one on the way.
Oakley Motorsports- BBF VENDOR SPONSOR
Re: vacuum pump ?
Oakley Motorsports wrote:thanks guys we got David one on the way.
Need a group high five on that one.................
Re: vacuum pump ?
Thanks guys! Today is the last day of my vacation on Sanibel Island, FL. Leaving sometime tonight for the 800 mile trip home, joy, joy....
Re: vacuum pump ?
David Willingham wrote:Thanks guys! Today is the last day of my vacation on Sanibel Island, FL. Leaving sometime tonight for the 800 mile trip home, joy, joy....
Be careful David, have a safe trip.
Re: vacuum pump ?
cool40 wrote:Nick i'll swap that junk pump you have for my nice 3yr old moroso next week when you get here.
my moroso is going on like 12 yrs lol
Re: vacuum pump ?
Saw my first vacuum with mine last night........... 10 lb at a about 3000 rpm
Re: vacuum pump ?
IDT-572 wrote:Saw my first vacuum with mine last night........... 10 lb at a about 3000 rpm
so what is it at 7500 ?
Re: vacuum pump ?
I will let you know Saturday night, I need you to ride with me and watch the gauge.
Re: vacuum pump ?
IDT-572 wrote:I will let you know Saturday night, I need you to ride with me and watch the gauge.
He won't do it. He's afraid of going that fast...!
jbozzelle- Posts : 3705
Re: vacuum pump ?
jbozzelle wrote:IDT-572 wrote:I will let you know Saturday night, I need you to ride with me and watch the gauge.
Re: vacuum pump ?
Doug Rahn wrote:Good memory Rick! Mine is the 4 bolt unit. Just before my engine was built, Peterson didn't have a Ford 4 bolt unit. So Phillip had me ship my damper to them and they made a prototype for me, hence why mine is not black anodized. Nick I have the Peterson Wet/Vac pump and pull about 8-10" of vacuum with two -10 lines to the lifter valley. Works good.
Where did that 4 bolt alt pulley come from?
soupbean- Posts : 637
Aerospace
Barney wrote:My Aerospace pulls 10 at 7500.
Is that with or without a vacuum regulator?
I picked up a remanufactured one from Aerospace real cheap, but it's the pump only, no reg, mandrel, pipe or fitttings. I'm really just wondering if a reg is necessary.
Beast- Posts : 66
Re: vacuum pump ?
Yes imo. Too much is not good.
Re: vacuum pump ?
Bruno, this is chip. I also went with the star pump the sportsman unit is what I use on my 557 and it works perfect with a little overdrive. I also use a dryer and a separator both because steve @ star said that their pumps unlike the Moroso or GZ need little to no oil pulled into the pump. I pull 10 @ 7100 rpm thru the traps.
HEMI-HUNTER- Posts : 10
Re: vacuum pump ?
HEMI-HUNTER wrote:Bruno, this is chip. I also went with the star pump the sportsman unit is what I use on my 557 and it works perfect with a little overdrive. I also use a dryer and a separator both because steve @ star said that their pumps unlike the Moroso or GZ need little to no oil pulled into the pump. I pull 10 @ 7100 rpm thru the traps.
whats up Chip !!!! yep had great luck with the star piece I got from Oakley Motorsports !!!!
Re: vacuum pump ?
Beast wrote:Barney wrote:My Aerospace pulls 10 at 7500.
Billy Glidden did an engine build for a magazine several years ago, and went with a vacuum pump on the dyno to see what sort of MAX hp the combination would put down.
Back to back testing showed on the big small block that exceeding 14 inches vacuum in the crankcase collapsed the oil mist and caused HP loss, most likely through increased ring friction. The test was regulated at 11" of vacuum and made most HP. I don't remember if the combination was put together with low tension rings or conventional rings. Article should be able to be found referenced on the interweb, it was a build with Billy Glidden and Jay Allen.
kim- Posts : 700
Re: vacuum pump ?
richter69 wrote:
what mandrel and ballancer is on this set up ?
10SHOTS- Posts : 587
Re: vacuum pump ?
Ati balancer and slmw generic mandrel i had a buddy of mine modify some. I have a new ati for my boss snout crank im gonna have to have him make a custom spacer for so it will all jive once again
» vacuum pump!
» when do you use a vacuum pump?
» vacuum pump ?
» Vacuum Pump
» vacuum pump!
» vacuum pump ?
» Vacuum Pump
Page 4 of 4
