Fluid dumping out of the glide!
BigDave65
soupbean
Fluid dumping out of the glide! Empty Fluid dumping out of the glide!
Post  soupbean March 14th 2012, 9:26 pm
Did some chassis dyno testing today and everything went fine. Went to load it on the trailer and I was alittle off point so put it in reverse to straighten up and drove onto the trailer. There was a large puddle of trans fluid in the area that I put it in reverse. Got back to the shop, put it in reverse to pull off the trailer and POURS fluid everywhere. So bad the exhaust made it cover the entire undercarriage of the car from the trans past the rear end. Put it on the lift and had a buddy watch, hit transbrake in park, nothing. Hit transbrake in reverse and the fluid seems to be dumping from the trans brake solenoid. Pulled the solenoid and nothing seems out of the ordinary. I'm not a good high pressure blower Laughing but couldn't blow air by mouth through the solenoid with the solenoid in either position. The solenoid seemed fairly snug when I took it out. Any thoughts???
soupbean
soupbean
Fluid dumping out of the glide! Empty Re: Fluid dumping out of the glide!
Post  BigDave65 March 14th 2012, 11:56 pm
Good chance the case is cracked, clean it and look it over really good.
BigDave65
BigDave65
Post  cool40 March 15th 2012, 12:00 am
glide?
Post  soupbean March 15th 2012, 12:04 am
Yes glide.
soupbean
soupbean
Post  soupbean March 15th 2012, 12:06 am
BigDave65 wrote:Good chance the case is cracked, clean it and look it over really good.
That was my first thought. Damn I hope not!
soupbean
soupbean
Post  cool40 March 15th 2012, 12:10 am
new power,new problems. pale
Post  soupbean March 15th 2012, 12:12 am
Razz It's been an interesting winter! 1 problem after another. I have caught myself more than once say I should have just sent the convertor off and left the rest alone drunken .
soupbean
soupbean
Post  soupbean March 15th 2012, 12:14 am
As a matter of fact, I think you were trying to tell me that before I started spending all my wifes money to begin with Cool 40 Cool .
soupbean
soupbean
Post  soupbean March 15th 2012, 12:16 am
Seriously though, any of you think even if there is an issue with the trans brake solenoid that it would have the pressure at that port to push that much fluid out that fast? I was just frusturated tonight and didn't investigate/troubleshoot too much, thought it was just best to get away from it for the evening and start again in the morning. Just wanted to see if you experienced fellars had some advice or direction.
soupbean
soupbean
Post  cool40 March 15th 2012, 12:29 am
my glide has 275 line psi so i'd think it would soak your ass lol. it'll all work out,just get it cleaned up and find the problem.maybe its not cracked. Smile
Post  soupbean March 15th 2012, 12:32 am
cool40 wrote:my glide has 275 line psi so i'd think it would soak your ass lol. it'll all work out,just get it cleaned up and find the problem.maybe its not cracked. Smile
She's testing my patience... And I don't have patience Evil or Very Mad
soupbean
soupbean
Post  cool40 March 15th 2012, 12:39 am
it could be worse...........what if that sumbich kicked a rod out on the dyno? affraid feal better now?lol
Post  dfree383 March 15th 2012, 12:59 am
affraid It could always be worse...^^^^^^^^
Post  powerstrokeace March 15th 2012, 1:02 am
Is there an o-ring on the solenoid?
Ace
powerstrokeace
powerstrokeace
Post  Oldani March 15th 2012, 5:00 pm
The reverse piston area of the case is one of the Glide's inherent weak spots. If the solenoid was loose it'd only dribble fluid out as there's no pressure at the point. Higher line pressures and excessive reverse clutch clearances can contribute to the case cracking at that area.
Oldani
Oldani
Post  soupbean March 15th 2012, 6:14 pm
Thanks fellas. Today I fired it up, put it in low, nothing. Hit the trans brake and fluid pouring from the solenoid. Just popped another one in. I think she'll be fine.
soupbean
soupbean
Post  soupbean March 17th 2012, 1:54 am
Oldani wrote:The reverse piston area of the case is one of the Glide's inherent weak spots. If the solenoid was loose it'd only dribble fluid out as there's no pressure at the point. Higher line pressures and excessive reverse clutch clearances can contribute to the case cracking at that area.
You were right. Case was cracked. Pulled it out, had a local guy put my guts in another case, had it buttoned up at midnight, gonna be at the track at 9am. Good times!
soupbean
soupbean
Post  bigblockfox468 March 17th 2012, 7:23 am
Cool Good luck and give er hell. Keep us posted Exclamation
bigblockfox468
bigblockfox468
Post  soupbean March 18th 2012, 1:12 pm
Gave er hell! Had the car back together and in the bed at 2am. Got to the track at 9:30am. They canceled fir rain! Oh well, atleast she ain't spittin fluid everywhere. We did get the chassis cert knocked out:)
soupbean
soupbean
