broke ground for new shop
+21
DFI429
Dave C.
bb429power
'65 T-BOLT
56Tbird
patfromjersey
bigblok2000ranger
STR-LGL-70
Dave Maxwell
25 posters
Page 5 of 8
Page 5 of 8 • 1, 2, 3, 4, 5, 6, 7, 8
Re: broke ground for new shop
I was told my floor would be like a Menards store. This shop has been a long time coming.
Dave Maxwell- Posts : 576
Not sure what a Menards floor looks like, but i bet it's shiny and smooth.
Dave C.- Posts : 1268
Lowes. Home depot. Same thing. Wanted bigger shop. Couldn't do it
Never big enough....Too much stuff.
Puting second floor up for storage. Was going to have 4,000 s/f floor. Ended up at 3000. Be close to 5,000 with partial second floor. Going to build rack to store my cars on. Stack em. Until I have time to work in them
Good idea....I built mine tall enough to put a lift in. The neighbors live me!!!
My neighbor hates me. Even though he signed an approval petition before I bought the house. Had to have lot rezoned
I sure wish I had a bigger shop but when its cold out or hot as hell Im glad I can heat and cool it lol.
He will change his tune when u change his oil...I empty my 8 gallon drain bucket every 3 weeks...its full of everybody elses oil! It works out though..
Nope no general repair. Its my hot rod Fab shop. Still will do little stuff at house garage. .I hope the in floor heat is as good as they say Richter.
Are you looking at the conventional blue/pink foam board, or the radiant barrier foam board with the foil facing?Dave Maxwell wrote:The foamboard was pricey. 3,000 just for it
DILLIGASDAVE- Posts : 2262
Foamular foamboard for radiant floors. 2 inch thick. 25 psi rated. No foil. Researched for over a year. Foil was always low in the ratings. Ownings corning. I would buy it when it was on sale. 24 bucks a sheet compared to 27. The 15 psi stuff I used around base. I went two feet down vertically along perimeter of walls. It was 23
The taller the roof/ceiling, the harder it will be to keep the warmed air close to ground level. My shop is about 20ft tall at the peak and I would swear there is at least a 15-20 degree difference in the winter between ground level & up on the office storage area.Dave Maxwell wrote:Nope no general repair. Its my hot rod Fab shop. Still will do little stuff at house garage. .I hope the in floor heat is as good as they say Richter.
Adding a large second floor storage area inside an existing tall shop should theoretically make the ground level area a little easier to heat in the winter by reducing the height (and cubic foot area) of the work area.
Dave Maxwell wrote:I hope the in floor heat is as good as they say Richter.
We have the radiant floor heat in our main hangar currently.. cat's ass as far as recovery in an often open/closed door situation. Although on a larger scale, everything's relative.. we have room for six fighters, and it doesn't take long at all to warm up after multiple aircraft movements
A shot with one of our former A-10s
Some ceiling fans will help push the heat back down. With the heat in the slab you will feel a noticeable difference over radiant or unit heaters.
Mike R- Posts : 1381
Sweet pic. My initial worry before build was the farmers telling me that after they took there equipment out. It took forever to recover. Said they have a forced air unit to help. Then I read and find out that radiant is the best for recovery
Infrared heaters will also heat the floor...Dad and I had a couple in our old shop.
On the sites about in floor. They say no fans. Which seems odd. I plan to put second floor up except for an area by the front door for my lift height. Will have a wall on that end of the second floor.
With a cot upstairs too! Perfect.
Dave Maxwell wrote:Sweet pic. My initial worry before build was the farmers telling me that after they took there equipment out. It took forever to recover. Said they have a forced air unit to help. Then I read and find out that radiant is the best for recovery
The mass in the floor is primary, and yes, any other mass (cars, etc.) remaining will greatly contribute to recovery time. I can honestly say I don't have any experience with the system on a smaller scale, but understand the principles that make it great
Upstairs will have AC and cable. Trophy and man cave area. Area for parts storage also. Anybody have experience grinding concrete.
I know a guy but he couldnt find his way up there I'm sure....Is the floor rough?
I'm not worried about recovery now after all the research. Not sure what the farmers issue was. Said when took combine out. The time it took to open door and move then close. Took forever to recover. Everything I have red says with the floor heated it recovers fast. Like your experience.
Yes the floor is rough in spots. The contractor is suppose to hire somebody. He is off work. He does it on the side. I am tired of waiting for him to get it done. Thinking about doing it myself
» Some SOB broke into my shop
» Setting up new shop What shop equipemnt?
» relay for tb
» Tornado on the ground !!!!!
» relay for tb
Page 5 of 8
