broke ground for new shop
+21
DFI429
Dave C.
bb429power
'65 T-BOLT
56Tbird
patfromjersey
bigblok2000ranger
STR-LGL-70
Dave Maxwell
25 posters
Page 6 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
broke ground for new shop - Page 6 Empty Re: broke ground for new shop
Post  Dave C. March 24th 2013, 1:17 am
Maybe the farmer was cold natured.....I think you're gonna like it...
Dave C.
Post  Dave C. March 24th 2013, 1:18 am
Yep thats pretty rough...
Dave C.
Post  Dave Maxwell March 24th 2013, 1:28 am
I don't even go out there because of the floor. Just brings me down to much. Don't want to see it
Dave Maxwell
Post  Dave C. March 24th 2013, 1:30 am
Does your guy own a grinder?
Dave C.
Post  Dave Maxwell March 24th 2013, 1:36 am
No. My worry doing it myself is how do you keep a flat level area. When the grinder hits an area previously ground what's stops it from lowering that area and leaving the floor wavy
Dave Maxwell
Post  DILLIGASDAVE March 24th 2013, 1:43 am
You don't want a shop floor that's too smooth. First time damp wether makes some condensation pop up on the floor & your slipping all over the place & busting your ass.
Post  Dave Maxwell March 24th 2013, 1:45 am
True. If I paint it I will put a anti slip on it. Just can't stand the bumpy crap on it now.
Dave Maxwell
Post  Dave Maxwell March 24th 2013, 1:46 am
Wouldn't want to roll a creeper across it now
Dave Maxwell
Post  Dave Maxwell March 24th 2013, 1:47 am
broke ground for new shop - Page 6 2012-12-11_16-34-07_133
Dave Maxwell
Post  dfree383 March 24th 2013, 2:27 am
from what I can see in the pictures, its not worth the time grinding if its just a very small area.
Post  Dave Maxwell March 24th 2013, 2:32 am
It has areas like that all over. Some bigger some smaller. I'm too picky I know. Paid good money though. It looks like crap. It was supposed to be basement quality. My show room.
Dave Maxwell
Double post
Dave Maxwell
Post  dave d March 24th 2013, 8:11 am
Hey Dave my son does concrete for a living check this out http://nickdancerconcrete.com/
dave d
dave d
Post  jeffgfg March 24th 2013, 10:08 am
Dave, it sucks that your floor came out so bad, I'll throw in my 2 cents. To have someone grind it "level" would probably cost as much as the floor was to pour. If doing it yourself the way to keep from digging or over grinding is to keep the grinder moving and watch carefully what you are doing. Basically you are evening up the rough spots. Be forewarned that there will be A Lot of dust!!!!!! Also you will have to seal the floor after grinding even if you are going to paint it because the paint will not stick to the floor after grinding. Sealer then paint. Concrete dust is so fine it will get Everywhere so make sure everything is out of the place before any grinding is done. Try this if you want take a small hand grinder (4") with a grinding disc and just try a small out of the way spot and see what it takes to even it out. As another option they offer large garage mats and the plastic tiles, maybe just in the main areas??
jeffgfg
Post  Dave C. March 24th 2013, 10:32 am
Not bad advice...I use cheap low pile carpet everywhere except the lift area...Looks good and super easy to replace ...We have a big fairgrounds here and I work a lot of side jobs there...I catch em throwing good/new stuff away and grab it off the fork lift !
Dave C.
Post  Dave Maxwell March 24th 2013, 1:27 pm
I thought you were supposed to grind prep for paint. Maybe I'll just use that clear epoxy sealer. If I have got to seal it anyway
Dave Maxwell
Post  Dave C. March 24th 2013, 2:17 pm
Dave if you seal it make sure you use the good stuff.Like i said i used some stuff i bought at Graingers that peals off the floor after the car has been parked on it...It sticks to the tires! I thought i was using the good stuff but obviously not. Crying or Very sad
Dave C.
Post  Dave Maxwell March 24th 2013, 3:33 pm
Grind job is $1250. If I use sealer. I will have the cobble stone look. If I grind and then acid etch. Can I paint then
Dave Maxwell
Post  Dave C. March 24th 2013, 3:36 pm
I think thats the next step...there is a lot of info on youtube to look at.
Dave C.
Post  Dave Maxwell March 24th 2013, 3:42 pm
Been watching alot of those. YouTube rocks. Think rental is a couple hundred a week. Have it done professionally is 1250. Sealer is 1500. I'm not paying for the grind job. Cement guy is. Just tired of waiting for him to get money. If grind guy could do it now. That would be great.
Dave Maxwell
Post  Dave C. March 24th 2013, 3:49 pm
It'll get done...how u feelin?
Dave C.
Post  Dave Maxwell March 24th 2013, 3:55 pm
Had to run to town earlier. About 5 miles. Laying down now. Feel like I've been drinking. I use to spend money to feel like this.
Dave Maxwell
Post  jeffgfg March 25th 2013, 5:29 pm
Dave do not use clear EPOXY sealer on your freshly ground floor!!! If you are going to paint it use a sealer supplied or recommended with the floor paint or go to a concrete supplier and tell them what you are doing to get the right product. If you use epoxy sealer on the freshly ground floor it will peel off. Acid etching is a great idea but... the main problem with that is getting the concrete acid free before painting/sealing it if not done properly it can make the paint not stick. It can be done for sure but it takes more than just a simple hosing off with water. I guess it must be pretty rough if they are going down to the aggregate. Usually there will be a layer of "cream" that comes to the top that gets finished if they grind through that you will see the stone.
jeffgfg
Post  Dave Maxwell March 25th 2013, 5:43 pm
I will look for a different paint supplier. Everyone said no seal before paint. Paint needs some texture to bite. Thank you for the heads up. Assume from everything I read any grinding exposed aggregate. I don't like aggregate get look. Wish I could just get a whole new pour. About 15 grand or so though. Any paint suppliers you recommend. I've been staying away from the box stores. Most of info so far is come from garage journal.com. thank you again for your help
Dave Maxwell
Post  Dave C. March 25th 2013, 7:54 pm
Yep..I have built two shops and didnt seek professional help on the sealer..I highly recommend it...Both of my floors peeled. Sad
Dave C.
