Broken washer in pan
+9
maverick532
Barney
Tore
13 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Broken washer in pan
dfree383 wrote:jbozzelle wrote:Is that a piece of a stop collar on the bottom of the dizzy housing?
Thats a damn good guess
Thats a good guess.
I gotta work late but I hope to get intake off and the dizzy will come out.
I checked the rockers and their perfect. If I can't see anything with the bore scope out it comes.
Tore- Posts : 865
Have you checked valve lash? If the lifter was broken in the roller area the lash "should" be looser on the base of the lobe with the broken roller compared to the other valves....
jbozzelle- Posts : 3705
That's what i was thinking also.Tore,what kind of distibutor MSD or Duraspark?I had a stop collar break on a Duraspark and think it kind of looked like that.Although that was a couple years back and i'm older and probably suffer from CRS[can't remember shit]syndrone.
Later Mark.
Mark Miller- Posts : 1959
Dawm ,that's what I got CRS!!!
Frank Merkl- Posts : 1524
Could it be off the cam retainer plate,one of the mounting lugs,
darren- Posts : 64
darren wrote:Could it be off the cam retainer plate,one of the mounting lugs,
Thats a good idea, I didn't make it to the barn last night I had to stay at work. Hope to leave at noon today so I can tear into it.
Thanks Tore
Tore- Posts : 865
Pulled the intake, nothing wrong with the lifters, Dist. is ok. Gonna get it up on the lift and take the bore scop and look in the oil pan. Without doubt engine is coming out.
Tore
Tore
Tore- Posts : 865
Shits gonna fly now,Tore's gonna give the green bird a colonostomy.
Run a magnet across the bottom of the pan and see if there's anything else in there.
[quote=
"jbozzelle"]Run a magnet across the bottom of the pan and see if there's anything else in there. [/quote]
I tried that already and didn't find anything else. I am gonna try that scope later and give it a whirl. Hell I will be able to give colononoscopys here in awhile. Come on up Rick and get em while there hot. Tore
Tore- Posts : 865
Take insurance ?
And what's the co-pay ?
John Myrick- BBF CONTRIBUTOR
No luck can't tell. Hope to pull it in the next week.
Tore
Tore
Tore- Posts : 865
If you are running rocker arm studs, check the bottom of each adjuster. Of course an enormous mount of valve lash should appear as well, unless it went un-noticed the last service.
Dave.
Dave.
LivermoreDave- Posts : 972
Tore wrote: I am gonna try that scope later and give it a whirl. Hell I will be able to give colononoscopys here in awhile. Come on up Rick and get em while there hot. Tore
Too late my friend,had mine done last month
Updates?
Rick don't have pollupsdfree383 wrote:Updates?
56Tbird- BBF CONTRIBUTOR
56Tbird wrote:Rick don't have pollupsdfree383 wrote:Updates?
Dano Be Drinkin' !!! LOL
No updates as of yet, I am to busy at work to pull the engine out. As soon as I can free up sometime I am going to pull the engine and drop the pan and find out whats going on.
I determined one thing thing Rick is full of crap .
Tore
Tore- Posts : 865
Watch out
Tore ,we all knew that years ago!!
Well I breezed work early and went home and pulled engine and put it on the stand. Pulled the pan and couldn't find one thing broken or missing. everything looked good as far as I could tell without pulling the timing cover.
I have another shortblock I can swap my heads to until I can get the shortblock in question apart.
Tore
Tore
Tore- Posts : 865
Page 2 of 2 • 1, 2
» 3/8 ARP 200,000 psi cam bolt and thin hard washer ,is the washer to thin
» If it was easy, everyone would do it...
» washer fluid injection
» Don't they use a copper washer under the attaching bolt on a oil filter adapter?
» Parts washer
» Parts washer
Page 2 of 2
