cam recomendations
fatal addiction
cam recomendations Empty cam recomendations
Post  fatal addiction April 28th 2012, 4:55 pm
I have a 632 Thor motor single Carb. Looking for some recommended can specs. 2.300 installed height. Wanting a Max effort deal. Thanks Eric oh rockers are open.
fatal addiction
fatal addiction
cam recomendations Empty Re: cam recomendations
Post  rmcomprandy April 28th 2012, 6:36 pm
fatal addiction wrote:I have a 632 Thor motor single Carb. Looking for some recommended can specs. 2.300 installed height. Wanting a Max effort deal. Thanks Eric oh rockers are open.
Buy your previous cam back from Smitty ... Idea
Post  fatal addiction April 28th 2012, 6:38 pm
Thought he had it reground?
fatal addiction
fatal addiction
Post  rmcomprandy April 28th 2012, 8:37 pm
fatal addiction wrote:Thought he had it reground?
Only the exhaust side to fix the excessive wear which showed on some of the exhaust lobe flanks; there is a different cam in his engine.
That should work well for your application.
IF he still has it.
Post  fatal addiction April 28th 2012, 8:43 pm
fatal addiction
fatal addiction
Post  fatal addiction April 29th 2012, 1:38 pm
I'm interested in that cam. But know body. Else has any recommendations???
fatal addiction
fatal addiction
Post  dfree383 April 29th 2012, 1:42 pm
It's not like you giving a lot of info...... Your probably best contacting some one to grind you one up if its a top secret max effort deal......
Post  fatal addiction April 29th 2012, 1:46 pm
What all u need to know nothing top secret here. 4.600 bore. 4 3/4 stroke16.5to1 comp. Heads just cleaned up 2.480 in. 1.88ex titanium valves. Don't have rockers yeaht waiting till I figure a good cam choice? Thanks
fatal addiction
fatal addiction
Post  dfree383 April 29th 2012, 2:07 pm
Whats the use? Trans? Gearing? Carb? Weight?
Post  fatal addiction April 29th 2012, 2:11 pm
Mud racing 3000# 5.57 gear powerglide 1.76 I don't shift. 6400 stall converter
fatal addiction
fatal addiction
Starting out with 1250 Carb. Might try a 1600 cfm later
fatal addiction
fatal addiction
Post  schmitty April 29th 2012, 4:51 pm
I would bet that carb won't be enough, Quick Fuel 1450 is seeming to be a good choice on the bigger engines that Phillip has been doing lately. That thing will be a beast in that buggy when you get it going. Hold on for dear life Shocked
Post  Barney April 29th 2012, 6:46 pm
Head flow #s and where?
Barney
Barney
Post  c.evans April 29th 2012, 10:27 pm
fatal addiction wrote:What all u need to know nothing top secret here. 4.600 bore. 4 3/4 stroke16.5to1 comp. Heads just cleaned up 2.480 in. 1.88ex titanium valves. Don't have rockers yeaht waiting till I figure a good cam choice? Thanks
In the directions A.T. sends with the heads, he suggests a 2.500" intake and a 1.840" exhaust. Kind of curious why you chose the 2.480" and the 1.880" sizes?
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  fatal addiction April 29th 2012, 11:17 pm
I talked to art personally and that's what he said to put in it??? I was pisses when he told me that cause we bought 2.520 for the intake and said to cut them down to 2.480??? Didn't make sense to me.
fatal addiction
fatal addiction
Post  rmcomprandy April 30th 2012, 10:21 am
fatal addiction wrote:I talked to art personally and that's what he said to put in it??? I was pisses when he told me that cause we bought 2.520 for the intake and said to cut them down to 2.480??? Didn't make sense to me.
Is nitrous intended to be used with this engine...?
Post  Barney April 30th 2012, 10:23 am
Big and big.
Barney
Barney
Post  fatal addiction April 30th 2012, 10:39 am
Nope.
fatal addiction
fatal addiction
Post  strokedmyford May 4th 2012, 8:51 am
cam recomendations 002
cam recomendations 001
This is the cam I run in my thor headed 605 with a 1.9 rocker ratio.
strokedmyford
strokedmyford
Post  fatal addiction May 4th 2012, 6:12 pm
OK guys I decided to beat the roller cam bearings out and pit a 60mm cam in what u think?
fatal addiction
fatal addiction
Post  rmcomprandy May 4th 2012, 6:26 pm
fatal addiction wrote:OK guys I decided to beat the roller cam bearings out and pit a 60mm cam in what u think?
Rolling Eyes
Last edited by rmcomprandy on May 4th 2012, 8:57 pm; edited 1 time in total (Reason for editing : I didn't originally realize that the question was merely rhetorical)
Post  Lem Evans May 4th 2012, 6:56 pm
Post  fatal addiction May 4th 2012, 7:35 pm
Thanks guys its only money..lol I don't want to run 1.9 rockers that's the reason behind the 60mm just what was recommended to me by a very intelligent motor builder?? Think I'm going with a 288-310 116 lsa some where around a .980ex 1.0in lift. The cam is only 200$ more supposably
fatal addiction
fatal addiction
Post  Lem Evans May 4th 2012, 8:04 pm
fatal addiction wrote:Thanks guys its only money..lol I don't want to run 1.9 rockers that's the reason behind the 60mm just what was recommended to me by a very intelligent motor builder?? Think I'm going with a 288-310 116 lsa some where around a .980ex 1.0in lift. The cam is only 200$ more supposably
If you have already desided on you cam specs I gotta wonder why you ask Rolling Eyes
Post  fatal addiction May 5th 2012, 4:08 am
Well I got my answer from the forum I have 4 or 5 pm's. Took all that info in and plus on the phone with roger at kasse thanks to everyone....
fatal addiction
fatal addiction
