Project EconoTow
+28
Bigred69
460pulling
jeffgfg
dave d
fatal addiction
Dave C.
QtrWarrior
bigblok2000ranger
prosandguy
72mav
bosshoss
lghting94
61coon
32 posters
Page 3 of 9 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Project EconoTow - Page 3 Empty Re: Project EconoTow
Post  Doug Rahn January 4th 2013, 6:47 pm
jasonf wrote:Are you putting skyjacker suspension on that thing? How come the motor is so low or does it just look wrong in the picture?
It is sitting a ride height on my fixture. As I stated earlier there will be about 6-7 inches of ground clearance for the pan. The front of that wooden cradle that then engine is sitting in is 7.5 inches. Plenty of room for a highway truck. I also chose it to be that low for the lower center of gravity and also to prevent any weird angles on the drive train.
Post  jbozzelle January 4th 2013, 11:36 pm
Will the body hang low enough to cover the engine or will you be able to see it?
Post  Doug Rahn January 5th 2013, 4:30 am
jbozzelle wrote:Will the body hang low enough to cover the engine or will you be able to see it?
Engine is completely hidden under rear deck.
Project EconoTow - Page 3 EconolineWithSideSkirtsSmooth
Post  Doug Rahn January 12th 2013, 8:49 pm
Surprisingly Shocked I got the front leaf spring brackets done today. I could have gotten more done, but was also working on my brothers Air Boat with an overheating issue.
Project EconoTow - Page 3 EconolineFrontSuspensionBrkts002_zpsf063e937
Post  Doug Rahn January 19th 2013, 1:16 pm
I just finished the passenger side engine mount a little while ago. Drivers side should go a lot faster now that I have a master pattern to go by, plus I need to make a trip to Lowe's and load up on some flap disc for my angle grinder. Just in case anybody is wondering what those are bolted to the heads, they're temporary braces so the engine doesn't move around on me while I'm fitting everything.
Project EconoTow - Page 3 EconolineEngineMount001_zps9301637e
Project EconoTow - Page 3 EconolineEngineMount003_zpsffb5c7a8
Post  res0rli9 January 19th 2013, 4:58 pm
Cool Well you wont be braking that mount. Smile
Post  Doug Rahn January 19th 2013, 5:32 pm
res0rli9 wrote: Cool Well you wont be braking that mount. Smile
Lordy, I hope not Laughing ! It's made from 1/4" thick plate, and a lot of dang welding. I think I got a little bit of tan this weekend on my arms lol!
Post  jbozzelle January 20th 2013, 1:28 am
Little bit of tan??? I just get sunburned...
Post  jasonf January 20th 2013, 12:46 pm
I like those mounts. How wide (thick??) are they about 1"?
Post  Doug Rahn January 20th 2013, 3:52 pm
jasonf wrote:I like those mounts. How wide (thick??) are they about 1"?
Overall thickness is 1-1/4".
Post  69F100 January 20th 2013, 5:40 pm
Doug will you be able to use the block hunger short headers like you posted up top.
Post  Doug Rahn January 20th 2013, 7:52 pm
69F100 wrote:Doug will you be able to use the block hunger short headers like you posted up top.
It's hard to see in the other two photos, but the mount is well forward of the center of the cylinder head and block. There should be plenty of room where the collector comes straight down.
Project EconoTow - Page 3 EconolineEngineMount005_zpsdbd26a50
Post  69F100 January 20th 2013, 9:54 pm
It looks alittle different in that photo ,what wheel base you shooting for
Post  bigblok2000ranger January 21st 2013, 1:08 am
I like it very inventive! That block mount looks very similar to a V8 S10 mount did you borrow the idea from one our just coincedence? Either way great work!
bigblok2000ranger
bigblok2000ranger
Post  Doug Rahn January 21st 2013, 8:01 pm
bigblok2000ranger wrote:I like it very inventive! That block mount looks very similar to a V8 S10 mount did you borrow the idea from one our just coincedence? Either way great work!
Thanks! Just a coincidence, I've never seen one.
Post  Doug Rahn February 3rd 2013, 6:32 pm
The only thing I got done this weekend was making the fixture to support the rear axle during mock up. I should have my tax refund by Thursday and then take a trip to a salvage yard in Hazlehust to get the rear axle from a 2000 F350 Dually bounce
Project EconoTow - Page 3 AxleFixtures002_zpsb48d83fb
Post  QtrWarrior February 3rd 2013, 6:37 pm
Doug Rahn wrote:The only thing I got done this weekend was making the fixture to support the rear axle during mock up. I should have my tax refund by Thursday and then take a trip to a salvage yard in Hazlehust to get the rear axle from a 2000 F350 Dually bounce
Don't plan on working on it next weekend either... Shocked
QtrWarrior
QtrWarrior
Post  Doug Rahn February 3rd 2013, 6:45 pm
10-4 Big Daddy. What day are we going?
Post  69F100 February 4th 2013, 1:05 am
Doug you getting it from McCarty if so he a old drag racer too I have bought from them years ago
Post  Doug Rahn February 4th 2013, 7:34 pm
That's the place.
Post  Doug Rahn February 9th 2013, 5:06 am
I picked this bad boy up yesterday. It had the ass end of the Ranger riding a little lower down the road Laughing Laughing . A lot of work to do before I put it in the fixture. Cut the spring perches off, shorten up axle tube on the drivers side to move the pinion to the center, and a few other little odds and ends.
Project EconoTow - Page 3 Dana80AxlePhoto_zps0037c914
Post  Doug Rahn February 16th 2013, 6:36 am
Well Mad , I ran in to a minor little snag that pisses me off more than anything. About 6 weeks ago I contacted Stainless Works about their block hugger headers ($490). Now, I've built many sets of headers over the years, but this time I wanted to avoid it to save a little time and there was something off the shelf was was perfect for my needs. I called this week during my lunch break to place the order, the salesperson I had talked to said they were showing inactive on his computer. He said he was going to contact the general manage and find out what the deal was. Later he called back and said they don't make them anymore. I asked can't you make one more set? But, noooooooooooo, they don't have the patterns and tooling anymore affraid Rolling Eyes Evil or Very Mad . Now what kind of idiot doesn't save their patterns? So out of curiosity I contacted another company that builds stainless headers and sent them the picture I had posted on here. They said $1200 Shocked Shocked . You've got to be freaking kidding me! I told them no freaking way am I paying that much for block huggers, I don't mind paying that much for full length race car headers, but simple non-complicated block huggers Suspect .
So now it looks like I've got to build my own Sad damn it!!!!!!!!!!!!!!!!!
Post  dfree383 February 16th 2013, 6:58 am
You try Sanders? and just coat them?
what about FPA?
Post  Doug Rahn February 16th 2013, 7:01 am
dfree383 wrote:You try Sanders? and just coat them?
Yep, primary's are to small.
Post  dfree383 February 16th 2013, 7:13 am
On shorties with an exhaust system it wont make a giant differents in the rpm range you will be towing in.
