1995 F150 pro Street project thread
+29
J.Toney
droppedf100
jones
bluef100fe
D. Sea
posford
motivated34
79Puller
460pulling
460bronco
ThndrChkn
kjett
lghting94
f250mike
Copperhead
jeffgfg
bigblok2000ranger
61coon
33 posters
Page 6 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
1995 F150 pro Street project thread - Page 6 Empty Re: 1995 F150 pro Street project thread
Post  bbf-falcon May 8th 2014, 11:46 am
Great work Alan. Wink
Post  f250mike May 9th 2014, 10:27 pm
It's already looking fast Twisted Evil
f250mike
f250mike
Post  bluef100fe May 10th 2014, 7:19 am
Alan, just a little warning... That shifter you have installed in your picture is not a good match for the detents of a c6 valve body... I had one transmission that had a short lived life because of that shifter.. I got a turbo action shifter after that mishap.. they come with a dedicated gate plate and shifter arm for the c6... It's expensive but worth every penny... Truck is really starting to look like something... Keep up the good work
bluef100fe
bluef100fe
Post  jones June 26th 2014, 5:49 pm
bluef100fe wrote:Alan, just a little warning... That shifter you have installed in your picture is not a good match for the detents of a c6 valve body... I had one transmission that had a short lived life because of that shifter.. I got a turbo action shifter after that mishap.. they come with a dedicated gate plate and shifter arm for the c6... It's expensive but worth every penny... Truck is really starting to look like something... Keep up the good work
Is there any other C6 shifters that work well?
jones
Post  HorsinAround November 25th 2014, 12:59 pm
Progress has been slow, but here is a few updates.
1995 F150 pro Street project thread - Page 6 0FCEF349-AAEA-43A0-BEBC-21D951D93E40_zpsr5ywwqnn
1995 F150 pro Street project thread - Page 6 961B140B-3309-4F7B-A9BC-E5806251A861_zpsnbfxmon7
1995 F150 pro Street project thread - Page 6 1512B9E2-D411-4C69-9C2F-E06C576850F5_zpskrzsbuht
Also Cody, I abandoned the B&M and went with a Hurst pistol grip quarter stick. Hopefully it will work better than the B&M Mega
http://www.frontpagefab.com
Post  schmitty November 25th 2014, 1:55 pm
Keep after it Alan, it looks killer. Twisted Evil
Post  droppedf100 January 4th 2015, 2:23 pm
Truck looks good man. Was your motor in the stock location when you had the headers built?
droppedf100
droppedf100
Post  jones January 4th 2015, 9:46 pm
droppedf100 wrote:Truck looks good man. Was your motor in the stock location when you had the headers built?
I certainly hope so! They was sold to me from maddog as stock location headers. If they where based off this truck I'm going to have problems with the steering shaft. I have been told that a 3" body lift will give me some clearance though. I don't like body lifts.
jones
Post  HorsinAround March 18th 2015, 9:58 am
Yes motor was in the stock location.
Here is a few update pictures.
1995 F150 pro Street project thread - Page 6 2015-03-06%2000.38.40_zpsr6byvy83
1995 F150 pro Street project thread - Page 6 375E72C2-3AC9-404D-A750-5FF8A7C39189_zpsy0iakzgg
1995 F150 pro Street project thread - Page 6 652FCE26-301D-4E9F-A966-89482A1E45A8_zpslylccfni
1995 F150 pro Street project thread - Page 6 4A266B99-AE5F-49FE-B221-23D445909EEB_zpsrnielinz
Post  bluef100fe March 22nd 2015, 9:34 am
Alan, I have no experience with the hurst shifter... Hopefully it's better than the megashifter... Truck is looking good..
bluef100fe
bluef100fe
Post  69F100 March 22nd 2015, 4:26 pm
Alan I pull the grill and head lights and grill support out of my 95 F350 to replace the passage side fender. I looked and don't see how to make the grill and support removable like the grill in my Ranger. The way you have to go about pulling the grill, head lights, and support with out adding to it to make it come out as 1 unit. But on good thing about the way yours will be you won't have batteries to pull and hard to get to place to get the nuts off of the corner/blinker lights. The truck is looking good.
Jim
Post  cool40 March 26th 2015, 12:30 am
Looking good! Is that a belt drive fuel pump? Suspect
Post  f250mike March 27th 2015, 10:34 pm
Hey Alan,
Is there a date for the maiden voyage??
I'm guessing Bunker Hill will be your test track??
If I'm welcome, I'd like to come help/watch or whatever.
f250mike
f250mike
Post  HorsinAround March 30th 2015, 11:51 am
cool40 wrote:Looking good! Is that a belt drive fuel pump? Suspect
Yes, it is a fuel pump. I am planning to do the initial start on gas, so I have a carb mounted right now. Once the rings are seated I'll install the Killer Ron's terminator injection system.
f250mike wrote:Hey Alan,
Is there a date for the maiden voyage?? No, I wish, but no.. My goal is to paint it this May. But it may not go down the track until after my daughter's wedding and a business trip in June.
I'm guessing Bunker Hill will be your test track?? Yes, Bunker is where I am planning to run most.
You bet. Welcome anytime.
Weighed the truck last night on a set of 4 corner scales and was happy to see the results. My goal was 3000 to 3200. She weighed in at 3050. Once I add the wheelie bars and fuel tank she should be 3150.
Post  cool40 March 31st 2015, 8:52 am
Im not sure how high in relation to the pump you plan to mount the fuel tank but the belt pumps like being mounted lower if possible. Just something to remember in case you run into fuel starvation issues. Wink
Post  HorsinAround March 31st 2015, 10:07 am
cool40 wrote:Im not sure how high in relation to the pump you plan to mount the fuel tank but the belt pumps like being mounted lower if possible. Just something to remember in case you run into fuel starvation issues. Wink
Thanks, I am concerned about that as well. I spent several hours playing with the alternator and fuel pump mounts and this was all I could come up with. I designed my own fuel cell that will sit up high in front and wrap around the core support so I am hoping this will prevent fuel starving. I got the tank finished up Sunday and hope to get it installed this weekend.
Post  HorsinAround May 7th 2015, 11:34 am
Got a little more done on the rod. This weekend I'll have the anti-roll bar installed and the aluminum tonneau cover done.
1995 F150 pro Street project thread - Page 6 2015-04-16%2023.33.08_zpsp054etnn
1995 F150 pro Street project thread - Page 6 2015-04-16%2022.04.12_zpstq8ro8cv
1995 F150 pro Street project thread - Page 6 2015-04-16%2022.03.37_zpsyatwrfmf
Post  schmitty May 7th 2015, 8:28 pm
Looking awesome Alan!!! Twisted Evil
Post  460pulling May 11th 2015, 12:55 pm
Nice work. Your truck is really coming along now. I think you will be happy once it is complete.
460pulling
Post  HorsinAround May 11th 2015, 2:00 pm
Thanks. We are nearing the end. My last night with the second job is Wednesday, and after next week's business trip, I will have a lot more time to get the turd done! I think I am less than a month away now.
Post  jbozzelle May 21st 2015, 9:06 am
How big of a rear tire?
Any pics of it on the ground?
Post  HorsinAround May 22nd 2015, 11:56 am
jbozzelle wrote:How big of a rear tire?
Hoosier 29.5x11.5w
Looked through all my pictures and don't see where I took one of it on the ground yet. I'll have it down on the ground soon and will get a picture.
Post  HorsinAround June 19th 2015, 10:45 am
Getting close now. Tonneau cover is done, fuel tank is mounted and got the lines ran last night. (got lucky here, the tank bung and the pump inlet are pretty close in height, so I shouldn't have a starvation issue). Window net installation is done, now just have the seat belts to install and the hood mounts to finish, then wiring.
1995 F150 pro Street project thread - Page 6 2015-06-11%2016.52.21_zps44geujcy
1995 F150 pro Street project thread - Page 6 2015-06-11%2016.52.06_zpsspobzniq
Also took time to put an epoxy coat on the trailer I picked up and had a generator door and roof prep done for A/C. Then scored a nice used A/C unit for very nice price. Just have to get the weather to quit so we can get it installed.
1995 F150 pro Street project thread - Page 6 2015-06-06%2014.35.57_zpsm9j3wpch
Post  cool40 June 19th 2015, 1:53 pm
Cool I know what you mean about the weather! !$&@)(;:&- rain almost every day here! Mad
Post  Copperhead June 22nd 2015, 10:32 am
Looking great Alan !!
If you don't mind,.....
Could you get some close up shots of how you did your window net mount?
I'm almost to that point on mine and I'm looking at a couple of different ways of doing it.
Copperhead
Copperhead
