1995 F150 pro Street project thread
+29
J.Toney
droppedf100
jones
bluef100fe
D. Sea
posford
motivated34
79Puller
460pulling
460bronco
ThndrChkn
kjett
lghting94
f250mike
Copperhead
jeffgfg
bigblok2000ranger
61coon
33 posters
Page 4 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
1995 F150 pro Street project thread - Page 4 Empty Re: 1995 F150 pro Street project thread
Post  HorsinAround May 13th 2013, 8:46 am
The out riggers are 2x4, .090. Right now, they are just welded to the frame as shown in the sketch that was in the kit. I am thinking of running a tube between the outriggers on each side to stiffen them up. Is it needed?
http://www.frontpagefab.com
Post  bigblok2000ranger May 13th 2013, 6:35 pm
No it its not needed unless you removed a bunch of the frame crossmembers.
bigblok2000ranger
bigblok2000ranger
Post  HorsinAround June 10th 2013, 11:07 am
Got the steering done on the project and welded in the passenger door bar. Then we took it down off the jack stands. First time the wheels have been on the concrete in several months. lol Next we concentrate on the firewall and dash while waiting on my custom master cylinder adapter to be done.
1995 F150 pro Street project thread - Page 4 IMG_0588_zps9ba1bb02
1995 F150 pro Street project thread - Page 4 IMG_0589_zpsd779b99e
1995 F150 pro Street project thread - Page 4 IMG_0590_zps3e2eda79
Post  dfree383 June 10th 2013, 12:19 pm
an X between the rear down bars is a good idea. Also wouldn't hurt to put rocker bars so it will certify if need be.
Post  HorsinAround June 10th 2013, 1:02 pm
dfree383 wrote:an X between the rear down bars is a good idea. Also wouldn't hurt to put rocker bars so it will certify if need be.
The last reply on page 5 from BigBlock2000Ranger says ".......As long as you don't modify the firewall at all or the floor in excess of 6' you do not have to run a rocker bar." So since I am not modifying the firewall (only filling in the oem holes) Do I need the rocker bar? Also, if it is needed, can I weld it in below the floor? I can easily attach from the front outrigger to the rear.
On the x brace, is there any thing specifying the angle of the bars or the length? I'm not finding it in the rule book.
Post  bigblok2000ranger June 10th 2013, 2:08 pm
They can be any length because they are not a requirement as the rocker bars aren't either. Not for an 8.50 cert. Being a truck you would be surprised at how little it takes to make it a 25.5 cert. If anytime during your cage install you don't understand something don't hesitate to call NHRA tech I had a bunch of questions because the way some of the rules are written and they had no issues answering my inquiries.
bigblok2000ranger
bigblok2000ranger
Post  HorsinAround June 12th 2013, 8:34 am
Thanks Eric,
Got a little more done last night. Converted to manual brakes and got the intake tapped for injectors.
1995 F150 pro Street project thread - Page 4 IMG_0596_zpsaa924ac8
1995 F150 pro Street project thread - Page 4 IMG_0597_zps267fa955
Post  69F100 June 13th 2013, 12:20 am
I know when I was building my truck I didn't have to run the rocker bars but had a few on here and the other site sub jest that I add them for future upgrade so I went ahead and added then, a lot easier than having to pull things back apart and adding them later on. I thought about it on a safety and added some more my cage is connected at 16 different points to the frame and outriggers
1995 F150 pro Street project thread - Page 4 Empty New Dash
Post  HorsinAround June 19th 2013, 12:07 pm
Got my new light weight dash and gauges installed. Really hoping the gauges work ok cuz I got a great price on them....
1995 F150 pro Street project thread - Page 4 Dash_mockup_zps3d2cc47b
Post  ThndrChkn June 21st 2013, 10:53 pm
I sure hope you sprayed that dash down with a good fire retardant... =-O
ThndrChkn
ThndrChkn
Post  HorsinAround August 14th 2013, 8:41 am
While I have pretty much taken the summer away from the project, I did decide to get the motor assembled. All I'm missing right now is the oil pump. Ignore the location of the head bolts. I had a DA attack and put the short ones on bottom. It was corrected before installing the heads....
[1995 F150 pro Street project thread - Page 4 IMG_0712_zpse7f3d391
1995 F150 pro Street project thread - Page 4 IMG_0726_zps268ed3cd
Post  HorsinAround August 23rd 2013, 3:57 pm
I hate body work, but it's all part of the game.
1995 F150 pro Street project thread - Page 4 IMG_0749_zpsb4825a63
Post  HorsinAround September 6th 2013, 10:09 am
Man, I hate body work....
1995 F150 pro Street project thread - Page 4 IMG_0776_zps970b68b3
Found some cracked bondo and when I started working on it, I found that they built it up almost 3/16" of an inch. When I started taking it out, I was shocked at how large of an area someone filled with the crap. The bare metal you see was all covered with bondo. You can see new bondo in the picture and this little amount was all that was needed.
1995 F150 pro Street project thread - Page 4 IMG_0781_zps8770568d
Post  Mike R September 6th 2013, 8:29 pm
Love those Fords with the accordion front ends
Post  460bronco September 7th 2013, 9:48 pm
All that bondo was meant to help weight transfer! Haha
460bronco
460bronco
Post  TravisRice September 10th 2013, 6:49 am
^^^^^^^^^^^^ Not to piss anyone off but the floor modifiactions pertain to the dash bar not the rocker bars. If the frame rails are in under the drivers seat then rocker bars are required on a full frame vehicle. The rocker bars can be above or below the floor as long as they are outside the driver. I can get the NHRA page pertaining to this and post it here if you like.
Post  HorsinAround September 16th 2013, 2:59 pm
Thanks Travis, could I weld a piece of 2x3 tube between the outriggers? This would be outside the driver seat. Or would it have to be round tube same as the cage?
Post  TravisRice September 16th 2013, 6:44 pm
1 5/8" x .083 CM or 1 5/8" x .118 MS >>>>>>>>>>>OR >>>>>>>>>> 2"x2" X .083 CM or 2"x2" x .118 MS ............. ALL MINIMUNS you can have.
Post  bigblok2000ranger September 25th 2013, 6:07 pm
My regional NHRA inspector said the rocker bars are NOT required on a TRUCK for an 8.50 certification and that the dash bar being required or not is dependent on whether the firewall is modified or not in excess of X amount and the rocker bars are dependent upon the floors or the transmission tunnel being modified in excess of 6'. The rules for a full framed truck are a little different than a full framed car.
But I did suggest to him that if he has any questions to call his NHRA tech inspector.
bigblok2000ranger
bigblok2000ranger
Post  HorsinAround September 25th 2013, 7:31 pm
I went ahead and ordered some tube to add them in. Better to have it and not need it, then to need it and not have it.
Post  bigblok2000ranger September 25th 2013, 7:45 pm
What tubing did you order? I would use 1 5/8" round tube below the cab.
bigblok2000ranger
bigblok2000ranger
Post  HorsinAround September 25th 2013, 7:50 pm
1-5/8.
Post  TravisRice September 26th 2013, 5:14 pm
bigblok2000ranger wrote:My regional NHRA inspector said the rocker bars are NOT required on a TRUCK for an 8.50 certification and that the dash bar being required or not is dependent on whether the firewall is modified or not in excess of X amount and the rocker bars are dependent upon the floors or the transmission tunnel being modified in excess of 6'. The rules for a full framed truck are a little different than a full framed car.
Take it for what it is worth ........ I've never had a car or truck fail chassis certifcation
Post  HorsinAround November 5th 2013, 11:45 am
Started working 2 jobs to raise some extra cash to buy parts so progress has slowed ALMOST to a stop. Good news is the shop is starting to fill up with parts.. I'm planning to work this second gig until I get the remaining big ticket parts bought. Then I'll be going after the project with a vengeance!
Finally got the chassis back from a fab shop where he formed the dash and console. Now I just have to finish it, and install the gauges, switches etc.
1995 F150 pro Street project thread - Page 4 Dash_zps21909e09
Post  Mike R November 5th 2013, 11:58 pm
Looking good Alan, making good progress and nice work
