New SCJ block....
+7
72mav
Tennessee Bullitt
8liter
11 posters
New SCJ block....
I talked to one of the reps at the FMS trailer during NMRA and asked about the 460 block situation. He said there was about 6 mo. worth of A460's left and then they are going to introduce the new SCJ block. I asked what the difference was, and he mentioned less weight and o-ringed freeze plugs. Anyone heard any other gossip?
8liter- Posts : 202
Re: New SCJ block....
I saw an article in the race pages they gave us at the gate. Pretty good info.
8liter wrote:I talked to one of the reps at the FMS trailer during NMRA and asked about the 460 block situation. He said there was about 6 mo. worth of A460's left and then they are going to introduce the new SCJ block. I asked what the difference was, and he mentioned less weight and o-ringed freeze plugs. Anyone heard any other gossip?
Both good improvements in my opinion. Just wish it wasn't taking so long, but given todays economy, I do understand.
Nevs- BBF CONTRIBUTOR
So does that mean there will be no more A460 block? I always assumed it was an in-between block like the boss units they have now.
jasonf- BBF CONTRIBUTOR
jasonf wrote:8liter wrote:I talked to one of the reps at the FMS trailer during NMRA and asked about the 460 block situation. He said there was about 6 mo. worth of A460's left and then they are going to introduce the new SCJ block. I asked what the difference was, and he mentioned less weight and o-ringed freeze plugs. Anyone heard any other gossip?
The SCJ block will be an improved A460 block as I understand it. It will actually be able to be bored to 4.6250" versus the A460 recommended 4.600" bore on the present stock. Lighter as well without sacrificing strength, 4 bolt mains and priority oiling just like the A460. All in all a nice piece when it happens. Maybe Lem will chime in, I'm sure he has more information than I.
i dont like o rings on the frezz plugs, no need for them,the old style was fine,,and you never had to take them out
-rich
-rich
BOSS 429- Posts : 2372
Where is it being cast?, U.S.? I hope not from overseas....
72mav- Posts : 1081
Yea, Don't see the need for the O rings. But, I'm not familiar w/A460 blocks eitherBOSS 429 wrote:i dont like o rings on the frezz plugs, no need for them,the old style was fine,,and you never had to take them out
-rich
Lem Evans wrote:The M-6010-A96 aluminium blocks had the oringed plugs....worked good .
Exactly, never had a leak on the one I had.
O rings plugs , most likely will be the same as the cup block . machined threads , so no stress from pipe plug
DanH- Posts : 1081
Tennessee Bullitt wrote:I saw an article in the race pages they gave us at the gate. Pretty good info.
That is an A460 Block in the article.
D. Sea- Posts : 2768
Pipe thread is very handy if you want to put water into the block through a core plug hole since the parts can be obtained via the lumber yard.
DaveMcLain- Posts : 399
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» Early style big block { c9v3 heads and block }
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» Differences between stock type block and the a460 block?
» If you swap from iron block to aluminum block,,,
