Mafia intake ?
+18
Albert Clark
Gary Blair
BigRigTech
gmsmkr
quikmule84
61coon
whitefield
22 posters
Page 3 of 4 Previous  1, 2, 3, 4  Next
Mafia intake ? - Page 3 Empty Re: Mafia intake ?
Post  gmsmkr January 21st 2016, 3:15 pm
Not trying to hi jack the thread mike but I got another question..
Weiand tunnel ram with the top removed will accept a 4500 flange what are the pro's and con's to running it set up this way??
gmsmkr
gmsmkr
Post  whitefield January 21st 2016, 3:22 pm
gmsmkr wrote:Not trying to hi jack the thread mike but I got another question..
No problem keep,asking and I will keep,reading and learning ! :study Wink
whitefield
whitefield
Post  IDT-572 January 21st 2016, 4:03 pm
Takes a ton more carb if no plenum is there. Might work on a below 400 inch deal
Post  Gary Blair January 21st 2016, 5:39 pm
You're going to need a plenum.
What size is your engine?
What type of car?
Gary Blair
Gary Blair
Post  gmsmkr January 21st 2016, 5:49 pm
Gary, no specific size I was just asking questions do to they will bolt on with out the plenum..
gmsmkr
gmsmkr
Post  Gary Blair January 21st 2016, 5:56 pm
gmsmkr wrote:Gary,  no specific size I was just asking questions do to they will bolt on with out the plenum..
I have ran the Weiand on a 466. The 750's were a little more consistent ET wise and weather changes didn't affect them as much as a pair of 1050 Dominators.
Dyno wise the Dominator's might make a tick more power. Track wise in my old Mustang the 750's and the 1050's ran almost the same ET wise. The 1050's had a little more MPH, about 1 1/2 MPH. These are just my results though.
Not many rum them, choosing to stay with a single carb. If you are bracket racing the ET doesn't have to be the fastest only the most consistent.
Gary Blair
Gary Blair
Post  Lem Evans January 21st 2016, 5:56 pm
IDT-572 wrote:Takes a ton more carb if no plenum is there. Might work on a below 400 inch deal
You'd have an I.R. manifold at that point and fuel stand off at the booster.
Post  Lem Evans January 21st 2016, 6:13 pm
IDT-572 wrote:
Gary Blair wrote:
Lem Evans wrote:Intake manifolding is like most other componets in an engine...it's application driven. I've had persons inquire about a "mafia" intake for their engine and advised them that they needed a Torker II....not a Victor or the TFS unit.
I'll use J.Y. Kell's 562" P51 engine as an example....it's been four years since it was done and a few things have changed but , I feel it is a valid example.
There was 17 more HP at the two manifold's peak power rpm in favor of the 'mafia' thing. The fully ported victor manifolds [w/o welding etc.] seem to hit a rpm number and immediately fall off.
Randy's engine with the 'mafia':
950.6 HP @ 6,700 rpm
950.6 HP @ 6,800 rpm
951.3 HP @ 6,900 rpm
950.7 HP @ 7,000 rpm
That's .7 Hp from 6,700 rpm to 7,000 rpm...seems the engine is hanging on to it's power.
I have two regrets....
1] The engine was not pulled to 7,200 rpm with the 'mafia thing'.
2] I did not get a copy of the dyno sheet for the best pull with the ported Victor.
Bottom line is that @ 7,000 rpm the ported victor had went back to the house and was down a lot more than 17 hp.
Yep, it's the same kind of deal with this engine.....the "Mafia" holds on to the power longer than a Victor.
1017 HP @ 6,600 rpm
1018 HP @ 7,100 rpm
Lem do you have any feed back regards to what the 17 HP is worth ET wise vs the Victor.
I agree it is application driven.
Gary, 17 HP is 17 HP,  who knows what E.T. difference it would make..............  In perfect back to back  runs it is what it is.
The deal is that, It makes more power in every test I have seen done, some more some maybe 2 hp less on engines that can test the boundary of the intakes. This isn't peak number either, it's across the usable rpm range.
Lem is just showing one more thing that adds HP to the engine we all love.  Not sales, not horn blowing, just concrete facts.
The Mafia generally peaks about 300 rpm higher than a Victor and brings that hp with it. It moves the tq peak up by that much too.
1017 HP @ 6,600 rpm
1018 HP @ 7,100 rpm
Mafia intake ? - Page 3 Shar_zpsfmd9iqqn
Post  gmsmkr January 21st 2016, 6:16 pm
how would you fix this
gmsmkr
gmsmkr
Post  IDT-572 January 21st 2016, 6:18 pm
Spacers to get the booster or venturie above the standoff ......... Same as a multiple carb bike engine.
Post  gmsmkr January 21st 2016, 6:22 pm
Thanks guys for the knowledge and help I can do more research on my end
gmsmkr
gmsmkr
Post  Gary Blair January 21st 2016, 6:31 pm
I would just like to see what the actual ET difference is.
Gary Blair
Gary Blair
Post  Gary Blair January 21st 2016, 6:34 pm
1017 HP @ 6,600 rpm
1018 HP @ 7,100 rpm
1017 HP @ 6,600 rpm
1018 HP @ 7,100 rpm
Lem I understand what you are saying. You have explained the dyno test's of several engines before.
I just want to see what the ET difference is. Like you say it's application specific.
Thanks for that dyno sheet.
Gary Blair
Gary Blair
Post  IDT-572 January 21st 2016, 6:35 pm
Ok Gary here is what you want to hear........... Nothing, zero, zilch, probably unperceivable at the track.
So that must mean the Mafia was a waste of time and effort and the Victor is the time honored king of intakes.
Probably best to even go back to the Weiand tunnel ram. But only if you run the A429s with it. There is nothing to compare to them, they all run within .05 of a second.
Post  Gary Blair January 21st 2016, 6:46 pm
IDT-572 wrote:Ok Gary here is what you want to hear........... Nothing, zero, zilch, probably unperceivable at the track.
I wouldn't know.
I was asking you the question.
Gary Blair
Gary Blair
Post  Albert Clark January 21st 2016, 7:15 pm
I wouldn't know.
Up yours Gary Blair  what have you done and I mean in this century, not back in the 70's.  today is a different Story I bet you built a Rochester 2 bbl 283 that made 1000 hp too  with a set of twice humped heads huh?
Up Yours Truly  Albert
Albert Clark
Post  richter69 January 21st 2016, 7:30 pm
https://youtu.be/7Iq1B-2paCs
Post  DILLIGASDAVE January 21st 2016, 7:38 pm
Albert Clark wrote:.........Up Yours Truly  Albert
Albert Clark always makes popcorn better. Laughing
Mafia intake ? - Page 3 Popcorn%20race%20car%20driver
Post  gmsmkr January 21st 2016, 8:45 pm
In for a good read Razz Razz
gmsmkr
gmsmkr
Post  Lem Evans January 21st 2016, 9:06 pm
1017 HP @ 6,600 rpm
1018 HP @ 7,100 rpm
1017 HP @ 6,600 rpm
1018 HP @ 7,100 rpm
Here is the way I see it:
If an engine has more power between peak tq and 300 -400 rpm past peak HP it ain't the engine's fault that it does not run faster.
Post  FalconEh January 21st 2016, 9:08 pm
what about the headlight? confused
Post  FalconEh January 21st 2016, 9:46 pm
1017 HP @ 6,600 rpm
1018 HP @ 7,100 rpm
1017 HP @ 6,600 rpm
1018 HP @ 7,100 rpm
I agree, in the quest for more hp/tq more is more. in order to see an et improvement a few variables must be met imo, if the car/driveline is less efficient than the engine all is lost, slippage of mechanical parts or maximum traction is exceeded it will likely slow down not due to lack of power but the sum of the total package. an extra 17 hp on my pit bike would be hard to control, 17 hp more on a car that black tracks will be wasted.
Post  supervel45 January 21st 2016, 10:49 pm
None of that matters, we are racing dynos here, if you can't make the extra HP work that is a personal problem. Razz
Post  whitefield January 21st 2016, 11:52 pm
Dang I missed a lot !
Gary ole Albert got a mouth like a cannon, always shootin' it off.
He ain't got know teeth he won't bite lol! lol! lol!
whitefield
whitefield
Post  Gary Blair January 22nd 2016, 11:09 am
I wouldn't know.
Hi Albert, I thought you had retired. Still only got 27 posts I see. Are you still using a file and a ball peen to build motors. Laughing
Gary Blair
Gary Blair
