Just built an engine and was wondering what kind of power it might produce!!!
1974 440.C.I.D.
Dodge 440
Lower end. KB 237 pistons .040 over, fully balanced, stock rods and stock crank. just turned.
902 heads 88cc's Motor should be right around 9.7 :1 compression ratio.
Full valve job of heads.
stock rockers and stock valves.
camshaft Comp kit K21-221-4 kit from summit racing.
lift .447int. and .455 exh.\
lobe separation 110
duration @50 212int. 218exh.
Aluminum intake
mopar performance ignition
I know its not a ford motor but You guys have helped me with all my 460 stuff... just figured maybe someone could crunch the numbers for me ... for some torque and hp specs... thanks
What kind of hp and tq numbers can I expect from this build.
Dodge 440
lobe separation 110
Aluminum intake
racinghabbit- Posts : 575
Re: Just built an engine and was wondering what kind of power it might produce!!!
400 hp 500 ft lb tq give or take a few pony's. If the heads are stock and dual plane intake, street type build.
» Buying an engine and want to know what kind of power it should have!!
» Is a 460 from an RV built different than a car or light truck engine ?
» Might be looking for a engine built
» Having an engine built.
» engine power vs 2 heads
