starting high comp. engine
+13
KY JELLY
ThndrChkn
bigblok2000ranger
Dave C.
Ashburner
fatal addiction
17 posters
starting high comp. engine Empty starting high comp. engine
Post  fatal addiction April 9th 2013, 11:11 pm
OK guys give me some ideas how to get the motor not to kick back on starter? Thanks
fatal addiction
fatal addiction
starting high comp. engine Empty Re: starting high comp. engine
Post  Ashburner April 10th 2013, 6:54 am
less advance at the distributor..
Ashburner
Post  dfree383 April 10th 2013, 6:57 am
I've never had an issue. You have a good starter? Strong Battery? Good Wiring / Cables?
And like has already been said proper timing?
Post  maverick April 10th 2013, 7:01 am
Toss in an MSD start retard. My ignition has one built in, works great. You can get an add-on unit, though. There's also a timing controller that will allow you to manually retard timing with a dial from the driver's seat.
Post  Dave C. April 10th 2013, 8:05 am
Is the advance locked out in the distributor?
Dave C.
Post  fatal addiction April 10th 2013, 8:08 am
I have the start retard. I'm thinking the starter needs replaced. If it keeps giving me trouble I'll just start it with 24 volt.
fatal addiction
fatal addiction
Post  maverick April 10th 2013, 8:33 am
fatal addiction wrote:I have the start retard. I'm thinking the starter needs replaced. If it keeps giving me trouble I'll just start it with 24 volt.
Had that same problem. After talking with MSD tech rep, I found that rotor phase needed to be moved ahead a little bit. Turns out that 24 degrees of retard was enough to allow the spark to jump to the previous cylinder in the distributor rotation, especially with small diameter distributor caps. Try it with your deal. Might work out for you.
Post  Curt April 10th 2013, 8:52 am
Yeah, I've seen fixed start retarders cause more trouble than they fix. I have a digital box and can control the amount of retard, and proper phasing is very important.
Post  fatal addiction April 10th 2013, 7:45 pm
I don't have a crank trigger. Do u rotor phase the small cap distributor? I've never done it before. Only on my old engine that had crank trigger?? Thanks
fatal addiction
fatal addiction
Post  maverick April 10th 2013, 9:00 pm
No crank trigger, no rotor phasing. Is your timing locked or are you running an advance curve? How much plug gap?
Post  maverick April 10th 2013, 9:03 pm
If you suspect a weak starter, try cranking with ignition off. I doubt that's your problem, though.
Post  richter69 April 10th 2013, 9:05 pm
you still need to check the rotor phase with a std dizzy, for sure with a start retard.......... start retard delays the signal. Get it phased and it should start like a new Buick.
Post  fatal addiction April 10th 2013, 9:20 pm
Yeah I don't think its the starter it kicks with the ignition off? Flex plate is good no missing teeth and has a good pattern from starter gear. This thing is makin me mad I just want one motor in my life time to start good...lol
fatal addiction
fatal addiction
Post  richter69 April 10th 2013, 9:23 pm
if its kickin back w the ign off you have a mechanical issue, or power/ ground to the starter/battery
Post  fatal addiction April 10th 2013, 9:26 pm
Thanks guys I'll go through and check all my connections. I'll let u know what I come up with. Thanks again
fatal addiction
fatal addiction
Post  fatal addiction April 10th 2013, 9:27 pm
One more question is it worth the money to switch to 16volt? My system is 12volt.. thanks again
fatal addiction
fatal addiction
Post  cool40 April 10th 2013, 9:28 pm
fatal addiction wrote:One more question is it worth the money to switch to 16volt? My system is 12volt.. thanks again
no. Smile
Post  richter69 April 10th 2013, 9:29 pm
you bet your ass it is.....
Post  fatal addiction April 10th 2013, 10:00 pm
OK need a tie breaker???? Lol
fatal addiction
fatal addiction
Post  cool40 April 10th 2013, 10:06 pm
its your $$ and everybody who has 16v loves it. i never had the $800 to drop on it. Sad
Post  richter69 April 10th 2013, 10:26 pm
the charger makes the initial cost high, once you go 16v............ well use your imagination lol
Post  bbf-falcon April 10th 2013, 10:28 pm
I agree w/Cool40. If everything is right. Rotor phased,battery high,starter good,and timing correct,12v is plenty and it should start right up.
I had same issues as you w/Crank trigger,sob tore up starters and was just a real pia. I went back to a light springed dizzy and problems solved. I wouldn't have another CT OR locked dizzy shoved up my azz if I had room for a box car. jmo Very Happy
Post  bigblok2000ranger April 10th 2013, 11:30 pm
What trans and flexplate? Reason I ask is I had starter issues with my C6 when using a 164 tooth flexplate had to use a184 tooth. Had quite a few people say that can't be but I broke more than fifty starters with a couple different 164 tooth flexplates but never broke one since going to the 184 in eight years.
bigblok2000ranger
bigblok2000ranger
Post  fatal addiction April 10th 2013, 11:47 pm
164 tooth glide trans/ w1/2" rear motor plate. I looked around but couldn't find a 184 tooth for auto trans?
fatal addiction
fatal addiction
Post  69F100 April 10th 2013, 11:50 pm
I had problem with the 552 cranking slow and kicking back when hot.I have db mini starter off ebay all I had to do is go bigger on my battery cable and it fixed my starting problem.mine is all 12vt system
