Cyinder pressure???
Dave C.
kim
1951 ford
Cyinder pressure???
Hey guys just did a compression test on my build . Dont think i even have an hour of run time on the engine and i'm seeing about 165 psi and all cylinders. Is this good and will it increase once engine is broken in ?
1951 ford- Posts : 34
Re: Cyinder pressure???
Good or bad depends on cam, ring gap, and most importantly, was it warm and sealing or cold? Was the throttle held wide open? Lots of variables affect that reading, the most important thing is that all cylinders seemed equal.
kim- Posts : 700
engine was cold throttle wasn't open .new to this whole thing . cam is an comp cams XE274h
1951 ford wrote:engine was cold throttle wasn't open .new to this whole thing . cam is an comp cams XE274h
When I had the same cam in my 460 with the stock dish pistons and dove heads it had around 170psi
Whats the Mechanical compression?
flat tops with dove-c's so 10.5:1 ish i think
Warm it up and open the carb and it will be a good bit higher.
Just curious, what initiated a cranking compression test?
Dave.
Dave.
LivermoreDave- Posts : 972
If you advance the camshaft you will get more cranking compression however, that certainly doesn't mean it will make more power; maybe even less.
» Good C6 Line Pressure at 1000 rpm? And more... Stacked shift, Line pressure not changing at different vac levels
» how to fix my oil pressure
» pressure in rad ???
» oil pressure
» Oil pressure
» oil pressure
» Oil pressure
