545 engine help
dave d
outbackbbf
545 engine help Empty 545 engine help
Post  outbackbbf September 3rd 2013, 7:39 am
Hi to all,
New member to bbf world in the process of building a possible 545 stroker, p51 headed engine for my 78 f100. It will need to run on pump fuel which is 91 octane generally. It has a C6 auto, 9inch diff, runs 35inch at tyres and a daily streeter. My thoughts of 650 rwhp, 6500rpm limit, will probably be looking for a good pulling engine. I would like some more educated advice on my build please. Looking at using a scat stroker kit. Is there a disadvantage of using a dished piston to get right cr, over a flat top or thicker head gasket? thanks in advance
outbackbbf
545 engine help Empty Re: 545 engine help
Post  dave d September 3rd 2013, 2:36 pm
Don't have the p51 head but running trick flow power port 290's 10-1 compression [pump gas] edelbrock torkor2 intake [ hood clearence ] 1050 carb just ran 10.56 @127 quarter at columbus and the car is 3250. So I'm sure with the p-51 is going to get you close to your goal----About time to add some nos to this car.
dave d
dave d
Post  Lem Evans September 3rd 2013, 2:39 pm
A dish piston is the way to go to get the compression correct for pump gas.
Post  rmcomprandy September 3rd 2013, 6:29 pm
outbackbbf wrote:Hi to all,
For 650 "WHEEL" horsepower in that vehicle you will need to make almost 800 "flywheel" horsepower.
Are you really ready for those kind of manners on the street...?. Personally, I would look for the TORQUE you are after and let the horsepower fall wherever it may.
Post  outbackbbf September 3rd 2013, 7:04 pm
[quote="rmcomprandy
Are you really ready for those kind of manners on the street...?. Personally, I would look for the TORQUE you are after and let the horsepower fall wherever it may.[/quote]
This is why im talking with the best, how do u build an engine to a torque figure not hp, HP =comp + air flow? I thought one would come with the other.
outbackbbf
Post  outbackbbf September 3rd 2013, 9:59 pm
So this is what im looking at so far,
Scat 4340 forged crank 4.500 stroke
Scat H beam rods 6.700 long
Bore of 4.390
Kaase P51 heads
Forged pistons to suit cr
Would I be better to run 6.800 rods ? what about be oil squirters? will the P51's be to big for a torque monster?
outbackbbf
Post  bbf-falcon September 3rd 2013, 11:15 pm
Either of the two that replied to your post can get you what you need as far as info,knowledge AND parts.They both are reputable BBF vendors. Both are experts in that catagory. Lem or Randy.
Post  69F100 September 3rd 2013, 11:45 pm
bbf-falcon wrote:Either of the two that replied to your post can get you what you need as far as info,knowledge AND parts.They both are reputable BBF vendors. Both are experts in that catagory. Lem or Randy.
Post  rmcomprandy September 4th 2013, 12:31 am
outbackbbf wrote:So this is what im looking at so far,
Bore of 4.390
Kaase P51 heads
What you have there is fine ... it is the intake manifold, carburetor, camshaft and valve train which will determine the throttle response and manners of the engine, AND the FTD, (fun to drive), factor...
Post  outbackbbf September 4th 2013, 6:30 am
want to use fast ezy efi fuel system
was thinking of an air flow manifold of some description
don't really have any thoughts on cam and valve train, what ever is going to work best with lump ofcourse Very Happy
do I need to pm you guys to talk further
outbackbbf
Post  rmcomprandy September 4th 2013, 9:25 am
outbackbbf wrote:want to use fast ezy efi fuel system
That system will never get you even near your horsepower goals; you would need a more involved system to get there if having fuel injection is your plan.
Post  outbackbbf September 5th 2013, 7:15 am
Not knocking your intelligence but they have a claimed 1200hp system, I haven't used that particular system but have many races on the older smaller efi. I can only go on what I read, hence the reason im on here for professional advice. should I call or email
Im sorry I believe I have offended, this was not my intention sorry again, The EFI kit no is SKU 30403, is this still not good enough?
outbackbbf
Post  outbackbbf September 6th 2013, 7:09 pm
outbackbbf
Post  rmcomprandy September 6th 2013, 8:00 pm
outbackbbf wrote:Not knocking your intelligence but they have a claimed 1200hp system, I haven't used that particular system but have many races on the older smaller efi. I can only go on what I read, hence the reason im on here for professional advice. should I call or email
The EZ-EFI 2.0 system is a more involved system for higher horsepower ...
The EZ-EFI, (not 2.0) is not the same system.
One throttle body has 4 fuel injectors and the other has 8 fuel injectors along with ECM and control differences.
One EZ-EFI 2.0 kit is for a multi-port injection for retro-fit applications or like the INGLESE injection.
Several different engine build specs you are looking for, to have 800 flywheel horsepower, are all over this forum.
Do some more reading since you said you are good at that type comprehension.
EDIT: that throttle body actually works better if mounted sideways with the injectors on the sides of the engine.
Post  outbackbbf September 19th 2013, 8:11 am
Thanks for info so far, At what point would rocker stud girdles be required?
outbackbbf
Post  dfree383 September 19th 2013, 8:57 am
Gridle's are a good idea with any performance application of your going to run stud mounted rockers.
When you say daily driver are you expecting something to last for 100,000 miles of daily driving?
Post  outbackbbf September 19th 2013, 9:07 am
No it would be lucky to do 150 miles a week, it takes me less than 5 mins to get to work, but I think I might go the long way round when she back on the road again (10mins)Laughing
outbackbbf
Post  dfree383 September 19th 2013, 9:50 am
I wouldn't get hell bent on trying to make the big numbers if you want it to last a long time and get alot of fun out of it.
And with your low RPM goals you may be a good canidate for a hydraulic roller cam, not the best HP choice, but it would be lower maintence and easy on parts.
