Ring seating
+8
LivermoreDave
kim
soupbean
samiam
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Ring seating
My exhaust smokes some on the pass side. Kinda barely see some at regular idle but see it pretty good when reved on. Driver side collector is rusty and pass side has the smut like oil like residue. Plugs are black on both sides though. Wondering if rings are washed or carb dumping alot of gas. Temp havent seen 200 yet. Its barely gotten to 160 or the temp sender and gauge is no good. I sure hope i dont have to pull this thing and rehone, rering or whatever. Can the carb be to rich from not enough air bleed?
Thinks for any info ideas.
tconnection- Posts : 866
Re: Ring seating
Maybe pulling oil past the intake gasket? I'd check there before I pulled it apart.
maverick- BBF CONTRIBUTOR
Re: Ring seating
Get some pretty good heat into it and give it a chance . 160 is just warm,it needs heat.
Re: Ring seating
Its a 580ci and yea, if the temp sender and guage is working it has only gotten up to 160 or 170. If i had some brakes on it i'll get out in front of the house and get on the trans brake a few times. Im ready to see how fast i can stand to go. Ive been cranking and revving on this thing alot.
As for the intake gasket, i think its been sealing now that i know where the water is seeping from.
As for the residue being on the pass side im assuming the driver side is a little the same but i have to reach up in the collector in the four tubes.
Re: Ring seating
Oh the carb is a qf 1250.
Re: Ring seating
X2 you need to get some heat in it I got mine up to 210* then let it sit until it is completely cool down done that a few times I never have seen any smoke out of it from oil. The only time I see smoke is when I fire it up after been sitting from the marvel oil I put in my carb to wash all the alky out of it.bbf-falcon wrote:Get some pretty good heat into it and give it a chance . 160 is just warm,it needs heat.
Re: Ring seating
Have you made any passes in the car yet?
soupbean- Posts : 637
Re: Ring seating
No i havent yet. Gotta little more ways to go.
Re: Ring seating
Maybe after a few passes and heat cycles they will come in. After a day of testing at the track, pull your headers and see if the exhaust ports are snotty. I think I have seen it posted on this site before and agree due to personal experience, if they have not seated by then, they most likely are not going to.
pic
This is what I wiped out of the pass side collector. The driver side is not like this.Any idea what's up with this?
Re: Ring seating
Good news, that aint oil. That's way fat on gasoline. Bad news is you need to correct it before you do wash the rings out.
kim- Posts : 700
Re: Ring seating
what manifold and carb are you running?
Re: Ring seating
Take a sniff of the engine's oil. As much idling as the engine has seen and without adequate engine coolant temperature the unburnt gasoline that is displayed in your exhaust may be if not already creating lubrication issues. ALWAYS use a known good carburetor when starting or running in a new engine.
Dave.
Dave.
LivermoreDave- Posts : 972
Re: Ring seating
Looks like a mistake i've made from i assume being careless on the matter.The carb was two turns out at one point but after forever getting it crank it didnt like but about 1 and a 1/4 turn. It has 96 in the front and back.
Oh its a 580ci a460 set and a qf 1250. Dam i hope my engine aint f---ed up.
Anymore thoughts? What would you do next?
Re: Ring seating
My QFX 1250 is the same way........... I haven't taken time to try to correct it. It is way way way fat right off of transition.
I cleans up on the trans break but down the return road it looks like a diesel.
Re: Ring seating
Yea i can smell fuel in the oil.
Re: Ring seating
How to tell if the rings is washed out?
Re: Ring seating
Do a leakdown test.tconnection wrote:How to tell if the rings is washed out?
Charlie
c.evans- BBF VENDOR SPONSOR
Re: Ring seating
About what should the leak down rate be or just see if it leak down any at all? And that is using a regular compression tester, is it? I
Re: Ring seating
No, you buy a leak down tester specifically for this purpose. Read and follow the directions. Run the engine and get it warmed up, then shut it off and test every cylinder for leakage. If the gauge shows over about 12% to 15% leakage, (note some people will say less and some will say more), then LISTEN for where it is leaking.tconnection wrote:About what should the leak down rate be or just see if it leak down any at all? And that is using a regular compression tester, is it? I
1. Remove the radiator cap and listen for air coming through the cooling system. That will indicate a blown head gasket.
2. Air coming through the carb will indicate a bent or leaking intake valve.
3. Air coming through the header collector will indicate a bent or leaking exhaust valve.
4. Remove the breather cap from the valve cover, and listen there. Air coming through the crankcase will indicate leakage past the rings.
Charlie
Re: Ring seating
I really dont know what's goin on with this pass side. I havent did a leak down test yet nor tried another carb. Im exspecting the worst so these pistons will be for sale or trade for some a460 4.600's.
Re: Ring seating
If that's way to fat, any idea on how to fix or what to do?
Re: Ring seating
FIRST and before anything else change the oil and filter!
Dave.
Dave.
Page 1 of 2 • 1, 2
» Ring seating
» piston ring choice and preferred ring seat/breakin time ?
» Do they make a ductile Iron ring 5/64 X 4.39 bore or whats a good ring?
» Seating in rings
» ring gap
» Seating in rings
» ring gap
Page 1 of 2
