Carnage!!!! (pics)
+6
Dave C.
LivermoreDave
69bluehotrod
10 posters
Carnage!!!!  (pics) Empty Carnage!!!! (pics)
Post  69bluehotrod November 30th 2013, 8:36 pm
Found out what a Richmond gear set breaking point is this weekend... Shocked
Carnage!!!!  (pics) Broke3rd1_zps1e5a606e
69bluehotrod
69bluehotrod
http://rainbowvacuumsalesservice.com/
Carnage!!!!  (pics) Empty Re: Carnage!!!! (pics)
Post  LivermoreDave November 30th 2013, 9:02 pm
They all fail at some point and I can see why yours did!
Dave.
LivermoreDave
Post  69bluehotrod November 30th 2013, 9:06 pm
LivermoreDave wrote:They all fail at some point and I can see why yours did!
Dave.
What do you mean??
69bluehotrod
69bluehotrod
Post  Dave C. November 30th 2013, 9:46 pm
Pro gears?
Dave C.
Post  cool40 November 30th 2013, 9:49 pm
That aint good....pale
Post  LivermoreDave November 30th 2013, 10:04 pm
Contact pattern to far out toward the "heel", pinion could be raised (thicker pinion shim) a bit.
Dave.
LivermoreDave
Post  69bluehotrod November 30th 2013, 10:32 pm
LivermoreDave wrote:Contact pattern to far out toward the "heel", pinion could be raised (thicker pinion shim) a bit.
Dave.
interesting, this is the only thing I DID NOT change on the rebuild, have had this 3rd member a lot of years... bunch of runs...
he next one is a complete MARK WILLIAMS aluminum set up.
Carnage!!!!  (pics) Mw3rd_zpsb7b4c33c
69bluehotrod
69bluehotrod
Post  69bluehotrod November 30th 2013, 10:34 pm
Dave C. wrote:Pro gears?
no Dave... just the regular stuff.... a lot of runs on this set
69bluehotrod
69bluehotrod
Post  the Coug December 1st 2013, 2:14 am
you know the Mark Williams spool and axles have a different pitch to the splines? I would rather use Mosier, beside mark is a D$#K last time I spoke with him....
Post  DILLIGASDAVE December 1st 2013, 4:37 am
I usually prefer a more toe biased drive pattern like this on a trans-brake/power-adder 9310 Pro gear drag combo.
Carnage!!!!  (pics) 9310gear
This is because the drive pattern will try to climb the ring gear a given amount (from down at "toe" up towards "center") under loading as more power/greater impact is added. More & more power can equal more & more drive pattern climb. If you start out with a more "street use" centered drive pattern on a drag combo, it's possible it can climb up toward (and even off) the heal of the tooth with enough power.
Post  70FB December 1st 2013, 8:52 am
Good info. I never new it moved that much.
70FB
70FB
Post  Dave C. December 1st 2013, 10:03 am
I,d run a steel case for the same reason.
Dave C.
Post  powerstrokeace December 1st 2013, 11:07 am
I just went through the same thing. Bought the Mark Williams rear and be done with it. If you don't put in a pro gear you only have limited time. I did not buy a strange replacement because they denied grinding the rear pinion support for the street gears to clear. I even had Jeff Strange evolved and they still didn't do a damn thing for me. Even though that support did not break 2 builders here in town would not touch it. even Mark Williams guys didn't really want to touch it as well.
Please call Mark Williams as they just sent out Emails with specials lower than what I paid. you can't beat them and they are the best on the market.
as for the gentleman saying mark was a Dick. There's two sides to every conversation.... just sayin
Ace
powerstrokeace
powerstrokeace
Post  richter69 December 1st 2013, 12:08 pm
steel case for the win......
Post  69bluehotrod December 1st 2013, 12:12 pm
powerstrokeace wrote:I just went through the same thing. Bought the Mark Williams rear and be done with it. If you don't put in a pro gear you only have limited time. I did not buy a strange replacement because they denied grinding the rear pinion support for the street gears to clear.  I even had Jeff Strange evolved and they still didn't do a damn thing for me. Even though that support did not break 2 builders here in town would not touch it. even Mark Williams guys didn't really want to touch it as well.
Ace
My thoughts as well.
69bluehotrod
69bluehotrod
Post  69bluehotrod December 1st 2013, 12:13 pm
richter69 wrote:steel case for the win......
Why a steel case???
69bluehotrod
69bluehotrod
Post  richter69 December 1st 2013, 12:19 pm
wont deflect as much as aluminum.
set an alum unit up and see how much a temp change affects the preload etc.
Post  cool40 December 1st 2013, 3:19 pm
No problems with my moser aluminum case.
Post  richter69 December 1st 2013, 3:41 pm
Six one way half a dozen the other.... My steel case has served me well the past 15 years.
You spend a day setting one up in an alum case to get the preload etc nice and smooth, come out the next morning after its cooled off and the things got tight spots in it now......
Buy what you want, makes me no difference...... The weight savings is next to nothing id rather have the stronger case.
Post  cool40 December 1st 2013, 3:50 pm
15 lbs.for the weight savings. Thats about what it comes down to.
Post  69bluehotrod December 1st 2013, 4:23 pm
Gear recommendation from you guys, had a 4.56 but all the calculators say to go with 5.29 for the specs and info that I have... Suspect
69bluehotrod
69bluehotrod
Post  richter69 December 1st 2013, 4:34 pm
How tall is the tire?
Post  69bluehotrod December 1st 2013, 4:53 pm
Jon they are 14 x32's
69bluehotrod
69bluehotrod
Post  cool40 December 1st 2013, 4:59 pm
What rpm does the motor like? 4.56 aint a bad gear IMO.
Post  richter69 December 1st 2013, 5:12 pm
Id keep the 4.56
