I have a build question????
95 ford ranger with 44 front and 9 in rear ... 460 with front and rear motor plates.... NO roll cage... leaf springs in the rear...
Should i use a rubber trans mount or a solid trans mount?
racinghabbit- Posts : 575
Re: I have a build question????
I've got a stock rubber one in mine and can't complain.
schmitty- Posts : 4538
is your motor mounted solid.?
My truck had a cage, front and mid plates with lateral limiters and I used a factory rubber trans mount with the cross member to mount bolts left loose(using lock nuts) to keep tranny/transfer where it belongs and to help support the heavy 205 transfer. I never had any issues with this setup.
lghting94- Posts : 762
Plates on both ends
schmitty wrote:I've got a stock rubber one in mine and can't complain.
same here. Keep the trans rubber mounted if you have motor/mid plates. it will help prevent the thin trans case from cracking if you have chassis flex.
kjett- Posts : 1169
» 514 blower build question
» 351 Boss build question.
» Engine build Question.....
» Engine build question??? a little more help , Please!
» newbie engine build question
