429 issues !!
+17
QtrWarrior
460bronco
69bluehotrod
glenevans
gt350hr
514Fox87
linearfab
21 posters
Page 6 of 7
Page 6 of 7 • 1, 2, 3, 4, 5, 6, 7
Re: 429 issues !!
QtrWarrior wrote:FalconEh wrote:QtrWarrior wrote:Ummmmm.
Pushrod length alone would not alter valve lift..
Only things that control the amount of lift are.. The cam lobe and the rocker ratio..
It would screw up the geometry big time
So why hasn't this motor smashed the valves and the push rods, the valve terrain goemetry has to be wrong, it can alter the lift IMO if it is the wrong length ie: too short, at peek lets say 6000 rpm when it misses the rocker lifts off the pushrod, the cam has enough in it, as do the springs and lifters so it doesn't float but it also never reaches maxium lift.
Ahhh No...
The pushrod only transfers movement.. If it is short enough to lose lift.. It would have spit it out by now..
Stood up for my opinion, but have been told...IDK!
FalconEh- Posts : 1448
Re: 429 issues !!
Ahhh No...
Valve lift near Top Dead Center is where the least piston to valve clearance occurs and retarding that camshaft about 1 tooth, (near 16.5 degrees), would lessen that lift near Top Dead Center on the intake about .060", (or so), CAM LOBE lift at that point.
Re: 429 issues !!
Put that dial indicator on that retainer , I'm curious what lift you come up with also.
nuclearcobra- BBF CONTRIBUTOR
Re: 429 issues !!
FalconEh wrote:Not to hijack the post but Dfree your new profile pick ...did you end it and how big was is nice hog!
He was about 150# and yes I put him in the pot.
Re: 429 issues !!
dfree383 wrote:FalconEh wrote:Not to hijack the post but Dfree your new profile pick ...did you end it and how big was is nice hog!
You did huh ??
QtrWarrior- Posts : 2703
Re: 429 issues !!
QtrWarrior wrote:dfree383 wrote:FalconEh wrote:Not to hijack the post but Dfree your new profile pick ...did you end it and how big was is nice hog!
You did huh ??
Well Dee did the pot part !
Re: 429 issues !!
My older brother in Fla used to hunt Boar with Pit Bulls and they would yank them down by the ear , when I was 12 i remember his friend Paul Hutchinson coming over for some help getting a live one outta the trunk of his Caprice Classic , and I was terrified at the rocking side to side and the sounds and the big dents that creature was kicking into the trunk lid , we didn't stick around to watch , me and my buddies peddled our butts outta there quick
Re: 429 issues !!
nuclearcobra wrote:Put that dial indicator on that retainer , I'm curious what lift you come up with also.
Ill grab my indicator and mag base from work tonight
linearfab- Posts : 72
Re: 429 issues !!
dfree383 wrote:QtrWarrior wrote:dfree383 wrote:FalconEh wrote:Not to hijack the post but Dfree your new profile pick ...did you end it and how big was is nice hog!
You did huh ??
linearfab wrote:nuclearcobra wrote:Put that dial indicator on that retainer , I'm curious what lift you come up with also.
you hammered him...and as long as it make te pot that`s too!
I will be suprised if it measures .475`lift
Re: 429 issues !!
I made sure to measure the intake side ! ( not an indicator but itll do )
2.000 - 1.300 = .700 .738 intake lift - .024 lash= .714 ... id say its there ! ill give my scaling tolerance +/- .030
but on a side note .. the throttle cable stretched and was only running on 2 barrels ... so that's pretty annoying .. gunna try it again this week at the track and see what happens ...
open
closed
open
closed
Re: 429 issues !!
are all corbra jet heads different than iron heads with valve location/angle .. or is it only the kaase redesigned ones ? .
Re: 429 issues !!
linearfab wrote: are all corbra jet heads different than iron heads with valve location/angle .. or is it only the kaase redesigned ones ? .
Aluminum SUPER Cobra Jet heads have different valve angles and locations and are the same valve placements as the later released Kaase P-51 heads; not the same as any Cobra Jet's.
Re: 429 issues !!
.rmcomprandy wrote:linearfab wrote: are all corbra jet heads different than iron heads with valve location/angle .. or is it only the kaase redesigned ones ? .
I see . Cool, thanks
Re: 429 issues !!
linearfab wrote: i found an old pic of the motor with out the heads . Here's my diamond pistons for the aluminum SCJ heads compared to your valve angles.
Re: 429 issues !!
Ya they are certainly different . Wish i had a bore scope so i could take a look in the cyl. I really hate to tear the motor completely down. Just to look at pistons that i already know about . Also hard to believe that both cams could of been installed. Way retarded both by different people woth out them mentioning shits screwed up . by the looks of it even with the cam way off. Itd prob still hit my pistons comparing the 2 motor pics . Id assume the valves would be drasticly bent or broken . . Car runs and revs fine . Not like it has a dead hole Or something no miss or Backfire through the intake or anything
Re: 429 issues !!
Well I think for that thing to work that camshaft has some seriously Retarded timing to clear....
Hey Nuc is that your short block? if so why all the rust? I hope you clean that before you put it together...
the Coug- Posts : 3055
Re: 429 issues !!
Naaa not rust just stained iron It did make it look horrible in that picture tho
Re: 429 issues !!
welp I put a bore scope in the cyl and the pistons are the same as the day they were installed back in the 90s . I discovered the throttle linkage was out of wack and was only getting a little over half throttle . I took it out on the street to see how itd run with the throttle corrected and it felt much better and the 6000 rpm stumble is gone .. taking it to the track tomorrow so ill post some times tomorrow evening
Re: 429 issues !!
Are you sure about the valve reliefs???
460bronco- Posts : 364
Re: 429 issues !!
It still doesn`t add up, as was previously mentioned unless the timing is seriously retarded it should make contact with those valve reliefs...do you know the part number of the pistons The only reason I can think of that the pisons would Not contact the valves other than the timing is if there is stroker flat top pistons in the motor with a reduced CR height.
Re: 429 issues !!
460bronco wrote:Are you sure about the valve reliefs???
yep ... just as I was sure what heads I had .. id put money on it . ive talked with the builder that put the heads on the motor . and I looked at them with a bore scope today and they look just like the pic I posted of the motor . nothing like the pics ive seen with 2 reliefs or just the "scj" reliefs.
Re: 429 issues !!
FalconEh wrote:It still doesn`t add up, as was previously mentioned unless the timing is seriously retarded it should make contact with those valve reliefs...do you know the part number of the pistons The only reason I can think of that the pisons would Not contact the valves other than the timing is if there is stroker flat top pistons in the motor with a reduced CR height.
yep L2366F-40
Re: 429 issues !!
like i said ill post up tomorrow how it runs ... what do u guys think itll run ?
Re: 429 issues !!
You need to invest in a degree kit, some clay and a couple of gaskets. You need to let us know how you are defying the laws of "the shit won't clear".....
I hate to call BS but I have messed with P-51 heads on dished conventional pistons and it would work with a small flat tappet...... But a roller of any size..... The laws of "that shit won't clear" is real......
Re: 429 issues !!
How thick of a head gasket do u guys normally run .. also why would i get in here to ask for help. Then lie to everyone about what i have . I have a degree wheel. But i dont have a piston stop that will screw into the head i guess i can turn one on the lathe at work this week end. And degree the cam And see . I dont want to tear the heads off unless i know forsure the cam is way off. Which i Was there when it was installed and the dots wher lined up but not while he degreed it . But if it runs decent tomorrow (11.50 -11.60s). Im not gunna touch it .
Page 6 of 7
