429 issues !!
+17
QtrWarrior
460bronco
69bluehotrod
glenevans
gt350hr
514Fox87
linearfab
21 posters
Page 2 of 7
Page 2 of 7 • 1, 2, 3, 4, 5, 6, 7
Re: 429 issues !!
Not that i dont agree that ur right on the heads and cam making it run better . Its obvious. That it ran better before . But id rather spend money to make more power than before . Not spend money and have what i had
linearfab- Posts : 72
Re: 429 issues !!
You have a few N/A options......
1 keep what you have and Add the inches 521-557 to get the combo inline with a heavy car and get it to run like it should and last.
2 don't add the inches and get a way looser convertor, a lot more gear and a better valve train and spin it to the moon knowing it's not going to last.
3 Put a way smaller cam in it and keep your convertor and gearing.
The carb is not a deal breaker right now but a dominator will run better especially when you add the cubes. But don't expect a dominator to go any faster unless you change what you have now the small carb
Is probably actual helping you right now.
Re: 429 issues !!
With adding cubic inch. Is the compression ok or should i look into a higher compression the car is mainly a strip caR might drive it in town for a cruise here and there
Re: 429 issues !!
11.5:1 is the nomans land IMO. At that point you being stupid, Either your building a race car or not.
Race car = 14:1+ and race fuel
Real street car = 10.5:1 or less and pump gas
Compression makes them fast.
Re: 429 issues !!
Guess ill have to decide that when the time comes . Thanks for in input guys !
Re: 429 issues !!
557 same heads same cam and a dommy it will break shit
Re: 429 issues !!
Haha im fine with breakin shit if its because its makin power ! . Sucks goin to the track with high hopes and runnin 12s . Hahaha. Which i dont claim to be an engine guy. I just trusted a guy that was supposed to know whats up .. obviously not !IDT-572 wrote:557 same heads same cam and a dommy it will break shit
Re: 429 issues !!
linearfab wrote:Haha im fine with breakin shit if its because its makin power ! . Sucks goin to the track with high hopes and runnin 12s . Hahaha. Which i dont claim to be an engine guy. I just trusted a guy that was supposed to know whats up .. obviously not !IDT-572 wrote:557 same heads same cam and a dommy it will break shit
guy the guys on here Most will lead you in the right direction just have to Listen, Most have been there done that....
the Coug- Posts : 3055
Re: 429 issues !!
the Coug wrote:linearfab wrote:Haha im fine with breakin shit if its because its makin power ! . Sucks goin to the track with high hopes and runnin 12s . Hahaha. Which i dont claim to be an engine guy. I just trusted a guy that was supposed to know whats up .. obviously not !IDT-572 wrote:557 same heads same cam and a dommy it will break shit
Thats why i registered on here .
Re: 429 issues !!
I no with small block stuff when u start messin with different strokes the block has to be clearanced . Is that also true for the bbf?
Re: 429 issues !!
Not with the BBF, just bore 080 over(most block will do this) and drop it in..............
Re: 429 issues !!
dfree383 wrote:You have a few N/A options......
It doesn't matter what anyone CAN do if they have 8 bent intake valves.
SCJ heads ... BIG camshaft ... Didn't have new notches machined in the flat top pistons = bent intake valves.
Re: 429 issues !!
I was thinking this was a Dooe-r head, piston notching is in his future too. Looks like they should be hitting now.
Re: 429 issues !!
IDT-572 wrote:I was thinking this was a Dooe-r head, piston notching is in his future too. Looks like they should be hitting now.
When he said he used to have IRON heads I figured these are now the aluminum SCJ ... but, maybe not.
This could be something like having a Super Victor intake manifold, though.
Re: 429 issues !!
Ya . Sorry. "Victor460" intake . They are the new alum scj head
Re: 429 issues !!
I might have missed it... but I did not see it the cam is installed advanced or straight up.. or Retarded ...
If you have the valve clearance have you tried to advance the cam??? before I would go throwing $$$$ at it ... I would at least give it a try... if you haven't already.
Re: 429 issues !!
The pistons have valve reliefs in them . I just recently had the heads off because of a broken lifter . While the heads wher off i had new PAC springs and retainers Put on them as recommended by bullet . Heads checked out fine ? No marks on the pistons from valve contact so.
Cam is in straight up
Re: 429 issues !!
linearfab wrote:The pistons have valve reliefs in them . I just recently had the heads off because of a broken lifter . While the heads wher off i had new PAC springs and retainers Put on them as recommended by bullet . Heads checked out fine ? No marks on the pistons from valve contact so.
I would move it to 2* + I bet it will help... I personally have never had any of my fords from SB to BB run good unless I advanced the cam at least 2*...
although the cam you have is a bit big... it is not a monster by any means...
I am however in agreement that more cubes is always a good thing....lol
Re: 429 issues !!
could be A429's? Got to assume the engine builder wasn't a total dingas..... But hey I've been wrong before....but honestly it would have wasters itself pretty quick with a cam in that range If they where hitting.rmcomprandy wrote:dfree383 wrote:You have a few N/A options......
Re: 429 issues !!
Whatever you do with cam timing be VERY sure you know what your valve clearance is.I agree it may need advancing to help low end power.if your not already familiar with a degree wheel it's a good time to learn.
Re: 429 issues !!
Valve reliefs...? In what location...? If these are the same pistons you used with the other heads then they should each have 2 different INTAKE notches to run with the SCJ's.
I think you should find out EXACTLY what you have before doing anything further.
Re: 429 issues !!
They are the same pistons we ran with the old heads . Im trying to find a picture with the heads off of it . But they r old trw forged pistons. Not. JE like i first stated . The pistons have been in the motor for probably 15 years or so purchased by my dad . Everything else is correct tho (correct as in type and brand )
Re: 429 issues !!
Post a picture of the heads you have on the engine now.
Re: 429 issues !!
Ill have to post pics later when im home from the shop. Or i can text you or someone pics for u guys to post . Wont let me post from my phone
Re: 429 issues !!
linearfab wrote: Im not gunna down grade the motor . Id rather make what i have work than go back to iron heads and a smaller cam . When i have a fortune in all of this and. The iron heads wher sold along time ago .
LOL, I never said go back to iron heads, JUST saying that they can be fun, I've made very good power with them.
ps, 4700lbs 64 gal-x-e 460ci dove heads,std bore...11.90 thru the mufflers c6,no power adder 1150 dom carb,4200 converter, 4.56 gear et streets
BOSS 429- Posts : 2372
Page 2 of 7
