638 C460 Headed BBF
+24
68galaxie
yellowhorse7
old blue
psfracer
Snowball Racing
rocketpony
STR-LGL-70
nuclearcobra
kjett
QtrWarrior
28 posters
Page 1 of 5
Page 1 of 5 • 1, 2, 3, 4, 5
638 C460 Headed BBF
Latest project with Oakley Motorsports
It's been in the works for awhile and here's what it's going to consist of.
Ford Racing A460 Block 4.625 bore
Callies 4.75 Stroke Forged Crank
Oliver 6.700 Billet Rods
Diamond gas ported flat tops with a rock and roll ring pack and upgraded pins
More to follow
More to follow
Re: 638 C460 Headed BBF
Nice
When are you expecting assembly and dyno?
Need pics and more details, keep us posted.
FalconEh- Posts : 1448
I'm thinking Jan or Feb on the dyno..... Pending The Thai War department allowing funding...
The "Commander and Chief" always gets approved for the funding
dfree383 wrote:I'm thinking Jan or Feb on the dyno..... Pending The Thai War department allowing funding...
That's the first step down the wrong path.....
QtrWarrior- Posts : 2703
QtrWarrior wrote:dfree383 wrote:I'm thinking Jan or Feb on the dyno..... Pending The Thai War department allowing funding...
You eyeballing me.....
Is it goin in the Digger
Approval?? Its easier to ask for forgiveness than it is permission, just sayin....
kjett- Posts : 1169
As soon as you start asking for permission, access will be denied frequently. If on the other hand you are more decisive, access is more at your discretion.
Should be a killer deal when you get it done. I'm gonna go out on a limb early and say you should get at least 625hp and at least 500tq.
schmitty- Posts : 4538
schmitty wrote:As soon as you start asking for permission, access will be denied frequently. If on the other hand you are more decisive, access is more at your discretion.
At half throttle?
dfree383 wrote:QtrWarrior wrote:dfree383 wrote:I'm thinking Jan or Feb on the dyno..... Pending The Thai War department allowing funding...
Nobody wants to ball you...eye or otherwise.
Lem Evans wrote:dfree383 wrote:QtrWarrior wrote:dfree383 wrote:I'm thinking Jan or Feb on the dyno..... Pending The Thai War department allowing funding...
Eye Eye Popeye!
Top end is a set if well worked C460 castings with Ti valves and PAC 1248 springs and complementing hardware.
Looking at T&D, Jesel or WW for rockers.
I'm going to run a ported Ford cast single 4 intake and a "Big" dominator.
Camshaft specs are still in the works and I'm considering a revised firing order.
Yep and only 900 cfm until ya smash the other two barrels opendfree383 wrote:schmitty wrote:As soon as you start asking for permission, access will be denied frequently. If on the other hand you are more decisive, access is more at your discretion.
At half throttle?
nuclearcobra- BBF CONTRIBUTOR
Sounds real close to what im gathering parts for right now, cept ill have. 16 fogger nozzels on mine ..... O_o
richter69 wrote:Sounds real close to what im gathering parts for right now, cept ill have. 16 fogger nozzels on mine ..... O_o
Ohhh forgot to mention the 8 fogger nozzles...
Be careful you don't studderrr they gave me a 1-1-1-3-3-3-7-7
Thats funny shit right there.
res0rli9- BBF CONTRIBUTOR
I was referring to the left side, the right side will be similar.dfree383 wrote:schmitty wrote:As soon as you start asking for permission, access will be denied frequently. If on the other hand you are more decisive, access is more at your discretion.
At half throttle?
Update!!!
windsor- Posts : 1167
The Thai War Dept. hasn't approved the budget for next year yet...
QtrWarrior wrote:The Thai War Dept. hasn't approved the budget for next year yet...
Flips working on the heads...... and approvals are not necessary for this "Black Ops" project......
Heads are done flowing 531 @ .950
Nice flow number there
» New C460 Intake Manifold M-9424-C460
» c460 pistons
» c460 cam.
» IF YOU LOOKING FOR C460 CAM
» Timing For C460 604 CID
» c460 pistons
» c460 cam.
Page 1 of 5
