638 C460 Headed BBF
+24
68galaxie
yellowhorse7
old blue
psfracer
Snowball Racing
rocketpony
STR-LGL-70
nuclearcobra
kjett
QtrWarrior
28 posters
Page 3 of 5
Page 3 of 5 • 1, 2, 3, 4, 5
Re: 638 C460 Headed BBF
Update - Short block should be done in a few weeks, heads are fixed and made right.
Thanks Lem for the parts and camshaft
Thanks Charlie and Mike for getting the heads fixed up and right.
Thanks Jet Boat Bob for the timely machine work and assembly.
Thanks Keith Fulp for the engine plate and pointer work
Hopefully on the dyno in mid February.
Need to work on the mandrel, oil pump and vac pump drives and accessories next, bolt the heads on and check clearances and measure for pushrods.
Sounds like you're getting closer! Who's mandrel are you going to use?
68formalGT- Posts : 865
Lem's got a connection with Peterson for a System that I'm probably going to use.
This beast is about to come alive, looking forward to seeing the result, Keep us updated man!
old blue- Posts : 124
Short Block is finally together!!
Next step measure for pushrods and check rocker geometry.....
Its getting there, want be long until this beast is thumping. Was curious what size of cam you went with, an is it out of lem's secret laboratory, his grinds makes monsters out of the c heads.
Yes it's a Double Secret Leminator Grind.
It's home..... now the work begins
dfree383 wrote:Lem's got a connection with Peterson for a System that I'm probably going to use.
Come get it!
old blue wrote:Any updates man?
Just need to adjust the valves and install the intake.
Also waiting on a mandrel piece needed one a little shorter than the std pieces.
Should be on the dyno next week end.
Motor is at Jet Boat Bobs waiting for the Dyno to be available
Sweet. Look forward to results.
windsor- Posts : 1167
dfree383 wrote:Motor is at Jet Boat Bobs waiting for the Dyno to be available
How many ahead of you Dave?
He's got a big iron A460 pulling motor on right now
EX514's?
68formalGT wrote:EX514's?
Yeah and it looks to be pretty bad ass
dfree383 wrote:68formalGT wrote:EX514's?
Is it cube limited? 48x
WoW ...
2 1/2 years and 3 pages of posts in the "Proven Builds" section about an engine which hasn't even been run yet.
[quote="dfree383"]Motor is at Jet Boat Bobs waiting for the Dyno to be available [/quotLook
Awsome, Looking forward to seeing the numbers it thumps out
rmcomprandy wrote:WoW ...
Previous shop 2.5 years+ no progress..... current shop 4 months and ready to dyno...... imagine that.
dfree383 wrote:rmcomprandy wrote:WoW ...
Just pointing out that this is "Proven Builds" not "Projected Builds". To some people there must be no difference.
Ya mean Oakley didn't come through for ya?? Imagine that lol
yellowhorse7- Posts : 1382
rmcomprandy wrote:dfree383 wrote:rmcomprandy wrote:WoW ...
The proof is on the way
» New C460 Intake Manifold M-9424-C460
» c460 pistons
» c460 cam.
» IF YOU LOOKING FOR C460 CAM
» Timing For C460 604 CID
» c460 pistons
» c460 cam.
Page 3 of 5
