Engine oil pressure
Engine oil pressure Empty Engine oil pressure
Post  dfree383 August 11th 2009, 10:39 am
Just looking at Franks back up monster motor dyno sheet, I noticed the oil pressure drop then pick back up. Any theories on what that might be?
Engine oil pressure Empty Re: Engine oil pressure
Post  dfree383 August 11th 2009, 1:44 pm
Frank you have a vacuum pump on that thing?
Post  Old blue Racin Team August 11th 2009, 2:48 pm
Very good Question
Old blue Racin Team
Old blue Racin Team
Post  dfree383 August 11th 2009, 8:32 pm
Bump for Frank......... bounce
Post  havinfun August 11th 2009, 9:36 pm
I think on the dyno sheet it says yes it has a pump.
Jay
havinfun
Post  Frank Merkl August 12th 2009, 10:10 am
Yes it has a vac pump
Post  Frank Merkl August 12th 2009, 10:19 am
I just checked all 11 runs and there all the same ,the oil pressure drops at the same range and then goes back up . Which I thing is due to the loose clearances that I run on the crank .0035 rods and mains ,looking at the old dyno sheets from my 600 it does the same thing and the bearings are always happy in it ! both motors also run a 5 stage peterson dry sump with a .875 pressure stage riven at 55%
Post  dfree383 August 17th 2009, 3:11 pm
It wasinteresting to see the pressure going to 80 with the juice on, I'm thinking the crank case pressure is spiking because of blow by?
